Civil Engineering Association eBooks Codes, Manual & Handbook IRC: 37-2012 Guidelines for The Design of Flexible Pavements (3rd Revision)
 i_kabir
Bangladesh
User ID: 741
Threads: 121
Likes: 3,231 in 259 posts
Given Likes: 446
06-20-2014, 03:22 AM (This post was last modified: 06-20-2014, 03:29 AM by i_kabir.)
Size: 4.6 MB | Format: PDF | Quality: Original preprint | Publisher: Indian Roads Congress | Year: July, 2012 | pages: 94
[Image: 84658040100785363365.jpg]
SCOPE OF THE GUIDELINES
The Guidelines shall apply to the design of new flexible pavements for Expressways, National Highways, State Highways, Major District Roads and other categories of roads predominantly carrying motorized vehicles. These guidelines do not form a rigid standard and sound engineering judgment considering the local environment and past pavement performance in the respective regions should be given due consideration while selecting a pavement composition.
For the purpose of the guidelines, flexible pavements include pavements with Bituminous surfacing over:
(i) Granular base and sub-base
(ii) Cementitious bases and sub-bases with a crack relief layer of aggregate interlayer below the bituminous surfacing
(iii) Cementitious bases and sub-bases with SAMI in-between bituminous surfacing and the cementitious base layer for retarding the reflection cracks into the bituminous layer
(iv) Reclaimed Asphalt Pavement (RAP) with or without addition of fresh aggregates treated with foamed bitumen/bitumen emulsion
(v) Use of deep strength long life bituminous pavement
These guidelines shall not be straightway applied to overlay design for which IRC 81-997 or a more suitable procedure based on evaluation of in situ properties of pavement layers by Falling Weight Deflectometer (FWD) should be used (25,56).
IRC: 37-2012 Tentative Guidelines for The Design of Flexible Pavements
Size: 4.5 MB | Format: PDF | Quality: Scanner | Publisher: Indian Roads Congress | Year: December, 2012 | pages: 96
[Image: 47230136737440092356.jpg]
[-] The following 12 users Like i_kabir's post:12 users Like i_kabir's post
  • Mohammad6299, blaze, dinu69in, Dell_Brett, malc, learner20, cace-01, PinkPant, eliseo.as, Andrew seah, Trishu999, Hengki
Users browsing this thread:
