Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Please upload BS 5974:2010
[Request] Please upload BS 5974:2010
 malee
User ID: 554
Threads: 20
Likes: 1,358 in 98 posts
Given Likes: 267
05-20-2014, 01:44 AM
Dear Forum member
i need your help to upload paper "BS 5974:2010
Code of practice for the planning, design, setting up and use of temporary suspended access equipment "
thank you for your kindness
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
05-24-2014, 02:59 PM
Solved here:
[-] The following 7 users Like st77bel's post:7 users Like st77bel's post
  • Mohammad6299, malc, Dell_Brett, er.shyams, zrilek, ir_71, malee
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
05-25-2014, 05:59 AM (This post was last modified: 05-25-2014, 06:02 AM by Mohammad6299.)
BS 5974:2010: Code of practice for the planning, design, setting up and use of temporary suspended access equipment
Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2010 | Pages: 62 | ISBN: 9780580530869
[Image: 63831966226685315892.jpg]
Temporarily suspended access equipment (TSAE) support or contain workers working at height on engineering and construction sites. BS 5974 gives guidance and recommendations on installing (erecting, altering and dismantling), maintaining, examining and using TSAE in a safe manner. It also sets out the responsibilities of all staff involved in working with TSAE.
BS 5974 makes recommendations for the selection, design, installation, inspection, use and maintenance of temporarily installed suspended access equipment/systems (TSAE), as defined in BS EN 1808. Non-standard installations are also covered by this code.
TSAE can be a working platform or platforms, work cage or chair suspended from a suspension rig which would be assembled at the place of work, used to carry out specific tasks. TSAE will then be dismantled and removed from the place of work when the specific tasks are complete to be used elsewhere.
The equipment referred to in BS 5974 is typically suspended from steel wire ropes that are attached to the outriggers of a suspension rig or other suitable high-level anchor point. It is capable of being raised or lowered by means of a winch or climbing device that can be attached either to the working platform(s), work cage or chair or be incorporated into the suspension rig. The lifting appliance or appliances can be manually or power operated. In certain instances, the TSAE can be incorporated into a system that allows it to be traversed horizontally.
Steeplejacks and steeplejack operations are not covered in BS 5974. It also does not cover permanently installed suspended access equipment, that equipment is covered by BS 6037-1.
Requirements for slung scaffolds, being working platforms on scaffold tubes or wire ropes but which cannot be raised or lowered by the user, are contained in BS EN 12811-1.
This version of BS 5974 is a full revision of the standard, and introduces changes as a result of the following:
• Changes in legislation, in particular the introduction of the Lifting Operations and Lifting Equipment Regulations (LOLER) 1998
• Advances in technology.
This version of BS 5974 replaces BS 5974:1990, which is now withdrawn.
Contents of BS 5974:
Foreword
Introduction
1 Scope
2 Normative references
3 Terms and definitions
4 Identifying hazards
5 Planning and exchange of information
6 Responsibilities
7 Health and safety
8 Types of temporary suspended access equipment (TSAE)
9 Materials and component selection
10 Righting and overturning moments
11 Design criteria of the TSAE and installation
12 Identification and registration of components and marking of working load limits
13 Electrical requirements
14 Protection against lightning
15 Installation, commissioning, handover and dismantling
16 Maintenance, thorough examination and testing of TSAE
17 Using TSAEs
18 Care of materials and equipment in store
19 Personnel and training
Annexes
Annex A (normative) Stability calculations
Annex B (normative) Scope and nature of thorough examinations
Bibliography
List of figures
List of tables
[Image: comments.png]
Credits go to st77bel. PDF file is optimized without reducing the quality of the images in the PDF file.
[-] The following 6 users Like Mohammad6299's post:6 users Like Mohammad6299's post
  • st77bel, malc, zrilek, Dell_Brett, malee, andersen3
  [REQUEST] Tunnelling Book Upload debpriya1984 0 1,700 01-31-2011, 02:42 PM
Last Post: debpriya1984
  [REQUEST] Upload Paper on Masonry analysis debpriya1984 0 1,557 09-20-2010, 08:58 AM
  Upload paper debpriya1984 1 1,851 08-17-2010, 01:48 PM
Last Post: ska51
