Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] SCI P939 Design of Composite Highway Bridges Curved in Plan
[Request] SCI P939 Design of Composite Highway Bridges Curved in Plan
 netsonicyxf
Senior Member
User ID: 12185
Threads: 79
Likes: 134 in 66 posts
Given Likes: 66
05-17-2014, 12:52 PM
Quote:This publication complements two earlier design guides for the design of composite bridges in accordance with the Eurocodes. It recognises that many highway bridges carry roads that are on a curved alignment and the supporting structure follows that curved alignment. The guidance addresses the consequences of the plan curvature on the design.
The publication discusses:
The options of using a series of straight girder lengths (chords to a curve) and of using curved girders.
The behaviour of curved elements, noting the torsional effects that arise, and the application of the Eurocodes to situations that are not always explicitly covered by its rules.
Consequences for construction (noting that the fabrication of curved girders is readily achievable in modern workshops) and the options for bridge articulation.
A short worked example illustrates the application of design rules to a two-span bridge, similar to the examples in publication P357 but curved in plan.
  â€¢
05-21-2014, 08:57 AM
Dear netsonicyxf,
you can find your document here:
I.R.
  â€¢ malc, blaze, netsonicyxf, Mohammad6299, zrilek, bridgeengineer
  [REQUEST] Design of Steel-Concrete Composite Bridges to Eurocodes Kurucz 0 1,627 07-28-2014, 07:44 AM
Last Post: Kurucz
  [REQUEST] Curved continuous beams for highway bridges netsonicyxf 0 1,547 05-16-2014, 02:26 PM
Last Post: netsonicyxf
  [REQUEST] Examination of Level of Analysis Accuracy for Curved I-Girder Bridges through Compari netsonicyxf 1 1,665 04-17-2014, 02:04 AM
Last Post: Mohammad6299
  [REQUEST] Highway Geometric Design: Application of Design Standards in InRoads fred2010 0 1,963 01-29-2014, 04:50 AM
Last Post: fred2010
  [REQUEST] Design of Steel-Concrete Composite Bridges to Eurocodes netsonicyxf 0 1,734 01-19-2014, 12:53 PM
  [REQUEST] Steel-concrete Composite Bridges: Designing with Eurocodes netsonicyxf 0 1,699 01-19-2014, 12:49 PM
  [REQUEST] Guide Specifications and Commentary for Vessel Collision Design of Highway Bridges vutuyen 1 2,377 01-24-2013, 02:35 AM
Last Post: vutuyen
