Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Behavior of RC Elevated Water Tankunder Different Types of Staging Pattern
05-10-2014, 08:16 AM
Author: Pavan .S. Ekbote, Dr. Jagadish .G. Kori, | Size: 1.4 MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Engineering, Computers & Applied Sciences (JEC&AS) Volume 2, No.8, August 2013 | Year: 2013 | pages: 07 | ISBN: ISSN No: 2319-5606
[Image: 53479474878488841519.jpg]
As known from very upsetting experiences, elevated water tanks were heavily damages or collapsed during
earthquake. This was might be due to the lack of knowledge regarding the proper behaviour of supporting system of
the tank again dynamic effect and also due to improper geometrical selection of staging patterns. Due to the fluidstructure interactions, the seismic behaviour of elevated tanks has the characteristics of complex phenomena. The
main aim of this study is to understand the behaviour of supporting system which is more effective under different
response spectrum method with SAP 2000 software. In this Paper different supporting systems such as radial
bracing and cross bracing.
  • vardan, ting tsai huang, zrilek, malc, rigid_joint, ashcivilea, cristi, ruaumoko
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,347 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 4,327 08-10-2014, 02:06 PM
  Comparison between Static and Dynamic Analysis of Elevated Water Tank” TAFATNEB 0 5,248 05-10-2014, 09:18 AM
  Seismic evaluation of fluid-elevated tank-foundation/soil systems in frequency domain TAFATNEB 0 4,275 05-10-2014, 08:32 AM
  Behavior of high frequency modal responses in non linear seismic  analysis  TAFATNEB 0 4,555 04-17-2014, 09:57 AM
  Proposal of lateral load pattern for pushover analysis of RC buildings TAFATNEB 0 4,129 11-23-2013, 12:32 PM
  Soil deformation pattern around laterally loaded piles asim99 0 3,676 05-06-2013, 04:09 PM
