Civil Engineering Association eBooks Journals, Papers and Presentations EARTHQUAKE RESISTANCE OF STRUCTURES AND DYNAMIC RESPONSE USING LARGE FACILITIES EXPER
04-23-2014, 03:44 PM
EARTHQUAKE RESISTANCE OF STRUCTURES AND DYNAMIC RESPONSE USING LARGE FACILITIES EXPERIMENTS
Author: Miloš Drdácký and Stanislav Pospíšil | Size: 305 MB | Format: PDF | Quality: Unspecified | Publisher: aInstitute of Theoretical and Applied Mechanics, Czech Academy of Sciences, Prague, Czech Republic | pages: 10
[Image: 29046206683568734341.jpg]
The presented article treats some of the activity of the Institute of Theoretical and Applied Mechanics of Czech Academy of Sciences (ITAM). It focuses on the experimental part of the research that has a broad field of application in the industry and/or that has been dealt within international projects funded by the European commission. The use of European and institutional facilities simulating the earthquake is presented as well as the methods of the structural assessment using dynamic response of
structures. Besides the experimental devices and methods used at the ITAM for assessment of vulnerability of structures to dynamic load are briefly mentioned
  • vardan, zrilek, ykhackhack, malc, ting tsai huang, PinkPant, slowet
  Fire resistance assessment of steel structures mowafi3m 1 5,904 06-19-2015, 12:21 PM
Last Post: Dell_Brett
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,042 12-26-2014, 09:49 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,114 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,082 09-05-2014, 01:46 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 4,205 08-14-2014, 07:39 AM
  Evaluation of dynamic properties of site and Response of Motion Si mulator Foundation TAFATNEB 0 4,302 08-11-2014, 10:49 AM
  DYNAMIC RESPONSE OF HIGH RISE STRUCTURES UNDER THE INFLUENCE OF DISCRETE STAGGERED SH TAFATNEB 0 4,566 05-30-2014, 01:55 PM
