Civil Engineering Association eBooks Journals, Papers and Presentations A DISPLACEMENT-BASED ADAPTIVE PUSHOVER ALGORITHM FOR ASSESSMENT OF VERTICALLY IRREGUL
04-09-2014, 05:51 PM
A DISPLACEMENT-BASED ADAPTIVE PUSHOVER ALGORITHM FOR ASSESSMENT OF VERTICALLY IRREGULAR FRAMES
Author: RUI PINHO ; STELIOS ANTONIOU | Size: 259 KB | Format: PDF | Quality: Unspecified | Publisher: 4th European Workshop on the Seismic Behaviour of Irregular and Complex Structures Thessaloniki, Greece, 26–27 August 2005 | Year: 2005 | pages: 16
Due to the unvarying nature of the applied displacement loading vector, conventional (nonadaptive) displacement-based pushover analysis can conceal important structural characteristics, such as strength irregularities and soft storeys, should the displacement pattern adopted at the start of the analysis not correspond to the structure’s post-yield failure mechanism. Consequently, when only non-adaptive static nonlinear analysis tools are available, as has been the case throughout the past, force-based pushover does constitute a preferable choice over its displacement-based counterpart. On the other hand, however, if one
is able to apply displacements, rather than forces, in an adaptive fashion, that is, with the
possibility of updating the displacement loading pattern according to the structural properties of the model at each step of the analysis, then a conceptually appealing deformation-based nonlinear static analysis tool would be obtained. The present study focuses therefore on the
verification of the accuracy of such an innovative displacement-based adaptive pushover method (DAP), to estimate the response characteristics of vertically irregular frames subjected
to earthquake excitation.
  β€’ rezart, malc, gulilero, ting tsai huang, cace-01, vardan, faros3000
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,365 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,924 08-10-2014, 02:42 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,267 04-11-2014, 09:13 AM
  Simple Method for Pushover Curves of Asymmetric Structure with Displacement-Dependent TAFATNEB 0 3,893 04-09-2014, 06:01 PM
  Seismic vulnerability assessment to slight damage based on experimental modal paramet TAFATNEB 0 3,675 11-18-2013, 07:55 PM
  Displacement-Based Design for Deep Excavations asim99 0 4,684 05-14-2013, 03:16 PM
  A new energy and momentum conserving algorithm for the non-linear dynamics of shells asim99 0 3,824 04-19-2013, 05:33 PM
