Civil Engineering Association eBooks Structural Books Concrete FIB 8: Lightweight aggregate concrete
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-28-2014, 04:45 PM
Size: 21 MB | Format: PDF | Quality: Unspecified | Publisher: fib | Year: 2000 | pages: 114 | ISBN: 9782883940482, 2883940487
[Image: 95513063715697209589.jpg]
[-] The following 14 users Like arshiakh's post:14 users Like arshiakh's post
  β€’ blaze, vvvv, warlord1, malc, Gabemzaman, Andrew seah, Jackass, mgdario, Trishu999, bigone, zrilek, Visitante, Mohammad6299, uetian19
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
03-10-2014, 09:48 AM (This post was last modified: 03-10-2014, 09:51 AM by bigone.)
FIB Bulletin_08 Lightweight aggregate concrete_2000-2883940487.pdf
[-] The following 4 users Like bigone's post:4 users Like bigone's post
  β€’ 3fan, gulilero, Mohammad6299, febo927
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
04-08-2014, 11:12 AM
Guide (part 1), technical report (part 2) and state-of-the-art report (part 3)
Size: 21 MB | Format: PDF | Quality: Scanner | Publisher: FIB - The International Federation for Structural Concrete (fΓ©dΓ©ration internationale du bΓ©ton) | Year: 2000 | Pages: 114 | ISBN: 9782883940482
[Image: 58778058790208577561.jpg]
Part 1 – Recommended extensions to Model Code 90
Starting in 1995 as a Joint CEB/FIP Working Group on Lightweight Aggregate Concrete (LWAC), the group was after the merger of CEB and FIP attached to the new fib Commission 8 Concrete. As a background for an extension of the CEB/FIP Model Code 1990 (MC 90) it delivered firstly Bulletin 4. Similarly to what has been done before in the field of High Strength / High Performance Concrete the present guide identifies the lacunae in the existing MC90 and proposes supplementary or alternative solutions to be applied for lightweight aggregate concretes. In order to facilitate its use the report is edited in two columns following the numbering of the CEB-FIP Model Code 1990.
The group has given preference to topics of practical importance for LWAC structures, and for which reliable information is available. Justifications of the proposed extensions are to be found in the references to each section.
Part 2 – Identification of research needs
The technical report identifies the research needs resulting from those clauses of MC 90 which need amendment, and for which more basic research should provide a better understanding of mechanical, physical and chemical processes.
Part 3 – Application of lightweight aggregate concrete
The state-of-art report documents 33 application examples of projects world-wide. Twenty-eight two-page and five one-page presentations aim to explain the motivation for adopting this technology and report on the design considerations and codes applied, the practical experience during design and construction, the results obtained and the infield performance; for each example references list the literature where more detailed information can be found.
[-] The following 5 users Like Mohammad6299's post:5 users Like Mohammad6299's post
  β€’ vardan, viet2010, jfjdm, Dell_Brett, bridgeengineer
  A Conceptual Model for Designing Recycled Aggregate Concrete for Structural Applicati ibg0203 0 1,517 03-30-2016, 03:55 PM
Last Post: ibg0203
  Recycled Aggregate in Concrete i_kabir 2 2,115 02-03-2015, 03:52 PM
Last Post: Veggeta
  Alkali-Aggregate Reaction and Structural Damage to Concrete: Engineering Assessment, ir_71 3 2,622 08-04-2014, 06:33 AM
Last Post: ssobhan
  FIB 4:Lightweight Aggregate Concrete, Codes and Standards arshiakh 0 1,513 02-28-2014, 04:33 PM
Last Post: arshiakh
  Structural Lightweight Aggregate Concrete datagap 5 3,796 01-23-2013, 11:38 AM
Last Post: ssobhan
  Lightweight Aggregate Concrete abudabeeja 4 3,867 08-20-2012, 11:40 AM
  ISE: Guide to the Structural Use of Lightweight Aggregate Concrete ir_71 1 2,155 04-15-2011, 10:29 PM
Last Post: bashir999
