Civil Engineering Association eBooks Journals, Papers and Presentations Pushover Analysis of Long Span Bridge Bents
12-12-2013, 08:35 PM
Author: Vitaly Yurtaev and Reza Shafiei | Size: 1.6 MB | Format: PDF | Quality: Unspecified | Publisher: Engineering Seismology, Geotechnical and Structural Earthquake Engineering | pages: 20
[Image: 17793856043717206766.png]
It has been observed that most of the bridges damaged in earthquakes were constructed before 1971 and had little or no design consideration to seismic resistance. Since the 1971 San Fernando earthquake in California, the standards for earthquake design have been strengthened considerably, and bridge structural behavior has been more accurately evaluated. Since then, structural ductility, a crucial element for the survival of bridges under severe earthquakes has become a key consideration in structural analysis and design. However, bridges that were constructed prior to 1971 are still in use and play important roles in our transportation systems, which may be susceptible to failure due to their structural deficiencies. To ensure safety and performance of these bridges, a seismic retrofit and strengthening program has been one of the major efforts of the Washington Department of Transportation and the Federal Highway Administration, aiming at improving seismic performance of older bridges. Retrofitting methods such as restrainers and column jacketing have proven to be effective in recent earthquakes. Techniques to retrofit other bridge members have also been developed such as soil anchors, footing retrofit involving increased plan dimension and reinforced overlay, construction of link beams, and system isolation and damping device. The goal of seismic retrofit is to minimize the likelihood of structural failure while meeting certain performance requirements. This allows engineers to design repair strategies based on performance needs. As a consequence, some level of damage may be acceptable during a design-level earthquake. The California Department of Transportation (Caltrans) has required that bridge retrofits provide survival limit-state protection at seismic intensities appropriate for new bridges. This makes possible the proposition of efficient and effective strengthening measures with optimized retrofitting schemes, and the adoption of the plan that is the most economical for the acceptable damage level. One of the ways of implementation the retrofit program for the structures is providing a nonlinear static analysis.
  â€¢ rezart, Dell_Brett, gulilero, subin91, junaid, vardan, blaze, learner20, malc, cace-01
  Long-term fatigue analysis of multi-planar tubular joints for jacket-type offshore wi TAFATNEB 1 6,143 06-19-2016, 12:48 AM
Last Post: englandboy
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 5,118 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,669 08-10-2014, 02:52 PM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 4,367 08-10-2014, 02:48 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,924 08-10-2014, 02:42 PM
  Seismic analysis of a three- span deck girder bridge TAFATNEB 0 4,141 05-03-2014, 09:01 AM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 4,288 04-26-2014, 06:15 PM
