Civil Engineering Association eBooks Journals, Papers and Presentations Effects of plastic hinge properties in nonlinear analysis of reinforced concrete buil
11-23-2013, 12:05 AM
Effects of plastic hinge properties in nonlinear analysis of reinforced concrete buildings
Author: Mehmet Inelβˆ— , Hayri Baytan Ozmen | Size: 1.1 MB | Format: PDF | Quality: Unspecified | Publisher: Engineering Structures 28 (2006) 1494–1502 | Year: 2009 | pages: 9
Due to its simplicity, the structural engineering profession has been using the nonlinear static procedure (NSP) or pushover analysis. Modeling for such analysis requires the determination of the nonlinear properties of each component in the structure, quantified by strength and deformation capacities, which depend on the modeling assumptions. Pushover analysis is carried out for either user-defined nonlinear hinge properties or default-hinge properties, available in some programs based on the FEMA-356 and ATC-40 guidelines. While such documents provide the hinge properties for several ranges of detailing, programs may implement averaged values. The user needs to be careful; the misuse of default-hinge properties may lead to unreasonable displacement capacities for existing structures. This paper studies the possible differences in the results of pushover analysis due to default and user-defined nonlinear component properties. Four- and seven-story buildings are considered to represent low- and medium- rise buildings for this study. Plastic hinge length and transverse reinforcement spacing are assumed to be effective parameters in the user-defined hinge properties. Observations show that plastic hinge length and transverse reinforcement spacing have no influence on the base shear capacity, while these parameters have considerable effects on the displacement capacity of the frames. Comparisons point out that an increase in the amount of transverse reinforcement improves the displacement capacity. Although the capacity curve for the default-hinge model is reasonable for modern code compliant buildings, it may not be suitable for others. Considering that most existing buildings in Turkey and in some other countries do not conform to requirements of modern code detailing, the use of default hinges needs special care. The observations clearly show that the user-defined hinge model is better than the default-hinge model in reflecting nonlinear behavior compatible with the element properties. However, if the default-hinge model is preferred due to simplicity, the user should be aware of what is provided in the program and should avoid the misuse of default-hinge properties.
  β€’ malc, vardan, rezart, blaze, RyanRS
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,426 04-20-2018, 05:19 PM
Last Post: munycamsec
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,647 08-01-2017, 09:19 AM
Last Post: abdulazizk
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,246 11-15-2014, 02:07 PM
  FRP (Fibre-Reinforced Plastic) Different topics mowafi3m 0 5,040 09-30-2014, 02:55 PM
Last Post: mowafi3m
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,366 08-10-2014, 02:59 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 4,812 05-30-2014, 01:43 PM
  DETAILING OF PLASTIC HINGES IN SEISMIC DESIGN OF CONCRETE STRUCTURES TAFATNEB 0 4,612 04-21-2014, 10:47 PM
