Civil Engineering Association eBooks Journals, Papers and Presentations FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS
11-20-2013, 12:11 AM
Author: MAR SALOM ON1 , SERGIO OLLER2 AND ALEX BARBAT2; | Size: 0.23 MB | Format: PDF | Quality: Unspecified | Publisher: INTERNATIONAL JOURNAL FOR NUMERICAL METHODS IN ENGINEERING Int. J. Numer. Meth. Engng. 46, 1741{1761 (1999) | Year: 1999 | pages: 21
A nite element formulation modelling hyperelastic quasi-incompressible rubber-like materials (elastomers) is
developed which takes into account large displacements and large elastic strains as well as inelastic e ects.
The capacity of laminated rubber-like materials to support high loads in compression and large displacements
in shear is the principal reason for their use in devices for seismic base isolation of structures. The energydissipation
capacity of these devices is increased by using high damping rubber, which is an elastomer
incorporating carbon black particles, or having lead-plug insertion. The Ogden strain energy function has
been used as a basis for the material model implemented in a total Lagrangian formulation, the strain being
decomposed into its deviatory and volumetric parts and the pressure variable being condensed at element level.
Mooney{Rivlin and neo-Hooke strain energy functions can also be used by simply changing the parameters of
the model. The stress{strain hysteresis, which appears when these devices are subjected to dynamic or quasistatic
cyclic loads, has been modelled by frequency dependent viscoelastic and plastic constitutive models. The
bearings have been modelled by means of an equivalent single element capable of describing the composite
behaviour of the actual isolation system. The proposed model is validated using available experimental results
and it is proved to be a powerful tool in dealing with di erent bearings. Finally, results for a six-storey base
isolated building subjected to the El Centro earthquake are given.
  â€¢ malc, ting tsai huang, cace-01, blaze
Threads: 49
11-20-2013, 07:25 AM
direct link
  â€¢ vardan, rezart, TAFATNEB, gulilero
  Strength reduction FEM in stability analysis of soil slopes subjected to transient un PinkPant 0 5,551 06-03-2015, 07:40 AM
Last Post: PinkPant
  Earthquake Resistant Design of Reinforced Concrete Buildings - Past and Future RyanRS 0 5,681 04-04-2015, 02:50 AM
Last Post: RyanRS
  ConPrimer-2 Finite Element emmi 0 5,218 03-27-2015, 12:59 AM
Last Post: emmi
  Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 5,791 12-26-2014, 10:12 PM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,049 12-26-2014, 09:49 PM
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,246 11-15-2014, 02:07 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,126 10-21-2014, 08:57 AM
Last Post: Munykong
