Civil Engineering Association eBooks Journals, Papers and Presentations Control of Seismic Energy Partitioning of Bridge Piers with Sliding Rubber Bearing
11-20-2013, 12:02 AM
Author: Hirokazu Iemura1 , Yoshikazu Takahashi1 and Youzhen Chen1 1 Dept. of Civil Eng. Systems, Kyoto University, Kyoto, Japan | Size: 0.38 MB | Format: PDF | Quality: Unspecified | pages: 8
[Image: 56207577170695747208.png]
Base isolation bearings have many good properties for seismic protection of bridges. Recently a new sliding rubber bearing was developed, which has both characteristics of sliding and rubber bearings. When we install these seismic isolation systems, reasonable inelastic design method is required. But since the conventional inelastic design method takes into account only bridge piers, it is hard to design seismic isolators which can cope with the interaction between seismic isolators and bridge piers. The purpose of this study is to understand the relationship between the seismic isolation systems and piers with respect to their energy dissipation etc. and to attempt to propose a design procedure for isolated bridges.
[-] The following 3 users Like TAFATNEB's post:3 users Like TAFATNEB's post
  â€¢ malc, cace-01, blaze
Threads: 49
11-20-2013, 06:45 AM
direct link
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  â€¢ vardan, gulilero
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,049 12-26-2014, 09:49 PM
  SEISMIC PERFORMANCE OF HIGH-STRENGTH-CONCRETE HOLLOW BRIDGE PIERS UNDER MULTI-DIRECTI TAFATNEB 0 4,345 06-03-2014, 08:39 PM
  ANALYSIS ON SEISMIC PERFORMANCE OF ENERGY DISSIPATION SUBSIDIARY PIERS CONSIDERING FO TAFATNEB 0 4,254 05-02-2014, 09:27 AM
  Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 4,363 05-02-2014, 09:08 AM
  Control of Seismic Drift Demand for Reinforced Concrete Buildings with Weak First Sto TAFATNEB 0 4,276 04-26-2014, 05:17 PM
  Response of Pure-Friction Sliding Structures to Three Components of Earthquake Excita TAFATNEB 0 4,308 04-23-2014, 03:49 PM
  Self-centering post-tensioned energy dissipating (PTED) steel frames for seismic regi arshiakh 1 5,374 07-20-2013, 11:27 PM
Last Post: Jackass
