Civil Engineering Association eBooks General Books Mechanics & Material Technology (Elasticity, Plasticity and Nonlinearity) Nonlinear Dynamic Phenomena in Mechanics
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
11-01-2013, 08:41 PM
Author: Jerzy Warminski, Stefano Lenci, M.P. Cartmell, Giuseppe Rega, Marian Wiercigroch | Size: 18 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2011 | pages: 292 | ISBN: 9400724721
Nonlinear phenomena should play a crucial role in the design and control of engineering systems and structures as they can drastically change the prevailing dynamical responses.
This book covers theoretical and applications-based problems of nonlinear dynamics concerned with both discrete and continuous systems of interest in civil and mechanical engineering. They include pendulum-like systems, slender footbridges, shape memory alloys, sagged elastic cables and non-smooth problems.
Pendulums can be used as a dynamic absorber mounted in high buildings, bridges or chimneys. Geometrical nonlinearities introduced by pendulum motion may change the system dynamics, and entail a rapid increase of the oscillations of both the structure and the pendulum, leading to full pendulum rotation or chaotic dynamics. To magnetorheological damping is proposed.
Nonlinear mechanics has to be used to explain undesired response in slender footbridges, such as that occurred in the famous event of the London Millenium Bridge. The observed phenomena can be explained by an analytical nonlinear discrete-time model.
Shape memory alloys (SMAs) exhibit very interesting nonlinear thermo-mechanical properties such as shape memory effect and superelasticity. SMA elements integrated within composite beams or plates can be used for active modification of structure properties e.g. by affecting their natural frequencies.
Finite amplitude, resonant, forced dynamics of sagged, horizontal or inclined, elastic cables have recently undergone meaningful research advances concerned with modelling, analysis, response, and nonlinear/nonregular phenomena. A variety of features of nonlinear multimodal interaction in different resonance conditions are comparatively addressed.
Non-smooth systems are very common in engineering practice. Three mechanical engineering problems are presented: (i) a vibro-impact system in the form of a moling device, (ii) the influence of the opening and closing of a fatigue crack on the host system dynamics, and (iii) nonlinear interactions between a rotor and snubber ring system.
This book is aimed at a wide audience of engineers and researchers working in the field of nonlinear structural vibrations and dynamics, and undergraduate and postgraduate students reading mechanical, aerospace and civil engineering.
Thanks to Original Uploader
[-] The following 3 users Like cace-01's post:3 users Like cace-01's post
  • malc, Dell_Brett, kowheng
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
11-02-2013, 09:42 AM
[-] The following 3 users Like ssobhan's post:3 users Like ssobhan's post
  • Dell_Brett, terrorruban, kowheng
  Nonlinear Mechanics junaid 2 2,894 12-22-2015, 10:15 AM
Last Post: PinkPant
  Stability and Nonlinear Solid Mechanics struceng 1 2,490 04-05-2015, 10:00 PM
Last Post: apocalipse
  Nonlinear Continuum Mechanics of Solids r3be1 0 1,791 08-14-2014, 08:36 PM
Last Post: r3be1
  Nonlinear Elasticity and Theoretical Mechanics struceng 1 2,453 07-29-2014, 04:51 PM
Last Post: r3be1
  Nonlinear Continuum Mechanics and Large Inelastic Deformations cace-01 0 1,748 07-29-2014, 12:55 PM
Last Post: cace-01
  Linear and Nonlinear Structural Mechanics timosi™ 7 5,157 06-09-2014, 07:53 AM
Last Post: Mohammad6299
  Nonlinear Solid Mechanics: Theoretical Formulations & Finite Element Solution Methods freequo 4 3,439 02-22-2014, 02:38 PM
