09-14-2013, 10:32 AM
An E cient Seismic Analysis Procedure for Torsionally Coupled Multistory Buildings Including Soil-Structure Interaction
Author: Erkan C ELEB _ I ; A. Necmettin G ¨ UND ¨ UZ | Size: 0.42 MB | Format: PDF | Quality: Unspecified | Publisher: _ Istanbul Technical University, Department of Civil Engineering _ Istanbul-TURKEY | Year: 2004 | pages: 15
![[Image: 10387159696618472883.png]](https://pic.civilea.com/images/10387159696618472883.png)
In this paper, a simpli ed methodology of analysis for the seismic response of 3-dimensional irregular
high-rise buildings on a rigid footing resting on the surface of a linear elastic half-space is formulated.
An e cient method using modal decomposition and carried out in the frequency domain by using the
fast Fourier transform to obtain the structural response of torsionally asymmetric buildings, including soilstructure
interaction e ects, is presented. Applying this algorithm, full advantage is taken of classical normal
mode approximation, and the interaction problem is solved easily and e ectively within the framework of
the Fourier-transformed frequency domain analysis for a xed-base structure. The matrix formulation of
this method produces accurate approximation with less computational e ort, in spite of using the frequency
dependent impedance functions.
