Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Effects of Soil-Structure Interaction on the Seismic Response of Existing R.C. Frame
Threads: 830
09-14-2013, 10:13 AM
Effects of Soil-Structure Interaction on the Seismic Response of Existing R.C. Frame Buildings
Author: M. Jawad Arefi | Size: 2.7 MB | Format: PDF | Quality: Unspecified | Publisher: Istituto Universitario di Studi Superiori di Pavia Università degli Studi di Pavia | Year: 2008 | pages: 100
[Image: 96658440222322504615.png]
Comprehensive experimental and analytical studies have been carried out to understand the behaviour of existing frame buildings constructed before the introduction of seismic design codes in 1970’s. Different aspects of the response have been investigated and inherent weaknesses have been pointed out. This usually has been done assuming a fixed-base structure while ignoring the flexibility of soil and foundation. In this thesis, the interaction between the super-structure and sub-structure (SSI) is investigated by modelling the soil as simple as possible to capture the overall response of the system.
As new analytical hysteresis rules and more advanced tools of analysis have been developed in recentyears, first the nonlinear response of a single-degree-of-freedom (SDOF) system which can be representative of a broad range of existing or newly designed structures, is investigated while allowing for flexibility of the soil-foundation system and SSI effects.
This simple soil model then is employed to existing nonlinear frame models to quantify the effect of SSI on the overall response of actual structures. The use of flexible base in the analysis can lead to reduction in the structural response and damage consequences in joints and infills. In a further step, the assessed existing frames are retrofitted in beam-column joints area and the effects of flexible base condition on structural demand are examined in more detail.
The results of this study suggest that the compliance of simply modelled soilfor typical building structures have in average beneficial effects in terms of structural demand especially for stiff structures. On the other hand, the governing component of these effects, i.e. rocking of foundation, can result in average to higher absolute deformation of floors which points out to potential pounding problems for structures existing in close vicinity to each other.
  • malc, rezart, isurya, vardan, gulilero, mgdario, ibmarin, Sumatra
  Dynamic Soil-Structure-Soil-Interaction Analysis of Structures in Dense Urban Environ TAFATNEB 0 1,758 07-03-2015, 09:25 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,913 03-27-2015, 11:44 AM
  Influence of Damping Systems On Building Structures Subject to Seismic Effects TAFATNEB 0 1,712 12-26-2014, 10:06 PM
  STEEL DISSIPATIVE BRACING SYSTEMS FOR SEISMIC RETROFITTING OF EXISTING STRUCT TAFATNEB 0 1,891 10-08-2014, 02:17 PM
  SEISMIC RESPONSE OF UNANCHORED CYLINDRICAL LIQUID-TANK SYSTEMS TAFATNEB 0 1,795 05-10-2014, 09:35 AM
  Performance-Based Seismic Demand Assessment of Concentrically Braced Steel Frame Buil TAFATNEB 0 1,838 05-09-2014, 05:09 PM
  Dynamic Soil-Structure Interaction of Instrumented Buildings and Test Structures TAFATNEB 0 1,847 05-09-2014, 04:25 PM
