Civil Engineering Association eBooks Journals, Papers and Presentations Modelling and Analysis of Infilled Frame Structures Under Seismic Loads
09-10-2013, 01:52 PM
Author: J. Dorji* and D.P. Thambiratnam | Size: 0.95 MB | Format: PDF | Quality: Unspecified | Publisher: The Open Construction and Building Technology Journal, 2009, 3, 119-126 | Year: 2009 | pages: 8
[Image: 06642263217097156643.png]
In-filled frame structures are commonly used in buildings, even in those located in seismically active regions.
Precent codes unfortunately, do not have adequate guidance for treating the modelling, analysis and design of in-filled
frame structures. This paper addresses this need and first develops an appropriate technique for modelling the infill-frame
interface and then uses it to study the seismic response of in-filled frame structures. Finite element time history analyses
under different seismic records have been carried out and the influence of infill strength, openings and soft-storey phenomenon
are investigated. Results in terms of tip deflection, fundamental period, inter-storey drift ratio and stresses are
presented and they will be useful in the seismic design of in-filled frame structures.
  â€¢ maad59, rezart, blaze, vardan, faros3000, malc, sodapas, subin91, pedzaquino
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,817 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,043 12-26-2014, 09:49 PM
  The application of ABAQUS in seismic analysis of connected structures TAFATNEB 0 5,164 12-26-2014, 09:40 PM
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,243 11-15-2014, 02:07 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,305 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,216 09-05-2014, 02:03 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 6,240 09-05-2014, 01:59 PM
