Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis BUILDING SEISMIC FRAGILITIES USING RESPONSE SURFACE METAMODELS
Threads: 830
09-02-2013, 09:25 PM
Author: Peeranan Towashiraporn | Size: 3 MB | Format: PDF | Quality: Unspecified | Publisher: Georgia Institute of Technology | Year: August 2004 | pages: 255
[Image: 77436357781640049618.png]
Building fragility describes the likelihood of damage to a building due to random ground motions. Conventional methods for computing building fragilities are either
based on statistical extrapolation of detailed analyses on one or two specific buildings make use of Monte Carlo simulation with these models. However, the Monte Carlo
technique usually requires a relatively large number of simulations in order to obtain a sufficiently reliable estimate of the fragilities, and it quickly becomes impractical to simulate the required thousands of dynamic time-history structural analyses for physics- based analytical models.
An alternative approach for carrying out the structural simulation is explored in this work. The use of Response Surface Methodology in connection with the Monte Carlo simulations simplifies the process of fragility computation. More specifically, a response surface is sought to predict the structural response calculated from complex dynamic analyses. Computational cost required in a Monte Carlo simulation will be significantly reduced since the simulation is performed on a polynomial response surface function, rather than a complex dynamic model. The methodology is applied to the fragility computation of an unreinforced masonry (URM) building located in the New Madrid Seismic Zone. Different rehabilitation schemes for this structure are proposed and evaluated through fragility curves. Response surface equations for predicting peak drift are generated and used in the Monte Carlo simulation. Resulting fragility curves
  • malc, kowheng, gulilero, blaze, Dell_Brett, sodapas, mgdario
  Numerical simulation of the wind flow around a tall building and its dynamic response bridgeengineer 0 3,041 04-20-2016, 11:27 AM
Last Post: bridgeengineer
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,913 03-27-2015, 11:44 AM
  SEISMIC RESPONSE OF UNANCHORED CYLINDRICAL LIQUID-TANK SYSTEMS TAFATNEB 0 1,795 05-10-2014, 09:35 AM
  Structural Response and Cost Characterization of Bridge Construction using Seismic Pe TAFATNEB 0 1,575 05-09-2014, 03:10 PM
  A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU TAFATNEB 0 1,769 04-12-2014, 02:40 PM
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,746 11-23-2013, 01:27 PM
  Seismic Response of Reinforced Concrete Structures Affected by Reinforcement Corrosio TAFATNEB 1 2,165 11-20-2013, 07:03 AM
