Civil Engineering Association eBooks Journals, Papers and Presentations SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WA
08-31-2013, 10:41 AM
SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WALLS
Author: SWAPNIL B. KHARMALE and SIDDHARTHA GHOSH | Size: 3.6 MB | Format: PDF | Quality: Unspecified | Publisher: Department of Civil Engineering Indian Institute of Technology Bombay | Year: 2011 | pages: 24
[Image: 27796124059431277993.png]
The thin unstiffened steel plate shear wall (SPSW) system has now emerged as a promising
lateral load resisting system. Considering performance-based design requirements,
a ductility-based design was recently proposed for SPSW systems. It was felt that a
detailed and closer look into the aspect of seismic lateral force distribution was necessary
in this method. An investigation toward finding a suitable lateral force distribution
for ductility-based design of SPSW is presented in this paper. The investigation is based
on trial designs for a variety of scenarios where five common lateral force distributions
are considered. The effectiveness of an assumed trial distribution is measured primarily
on the basis of how closely the design achieves the target ductility ratio, which is measured
in terms of the roof displacement. All trial distributions are found to be almost
equally effective. Therefore, the use of any commonly adopted lateral force distribution
is recommended for plastic design of SPSW systems.
  • slowet, gulilero, malc, kowheng, araza023, ruaumoko, subin91
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,663 08-04-2021, 08:44 PM
Last Post: Wijono
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,647 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,365 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,306 07-08-2015, 08:02 AM
Last Post: PinkPant
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,829 02-12-2015, 01:39 PM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 5,206 08-10-2014, 01:15 PM
  Lateral-torsional buckling capacity assessment of web opening steel girders by artifi ssobhan 0 3,870 08-02-2014, 10:21 AM
Last Post: ssobhan
