Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces
08-31-2013, 09:52 AM
Author: Rafael Sabelli, Stephen Mahin and Chunho Chang | Size: 0.44 MB | Format: PDF | Quality: Unspecified
[Image: 00297691230833826506.png]
This paper highlights research being conducted to identify ground motion and structural
characteristics that control the response of concentrically braced frames, and to identify
improved design procedures and code provisions. The focus of this paper is on the seismic
response of three and six story concentrically braced frames utilizing buckling-restrained
braces. A brief discussion is provided regarding the mechanical properties of such braces and
the benefit of their use. Results of detailed nonlinear dynamic analyses are then examined for
specific cases as well as statistically for several suites of ground motions to characterize the
effect on key response parameters of various structural configurations and proportions.
  â€¢ jcbv, slowet, gulilero, warbeast, malc, kowheng, mgdario, cristi, Dell_Brett
Threads: 49
11-28-2013, 12:06 PM
direct link
  â€¢ blaze, vardan, jcbv, Dell_Brett, draluka
  Evaluation of Concrete Cracking due to Restrained Thermal Loading and Shrinkage wafiullah 2 9,298 11-26-2020, 09:55 AM
Last Post: Dell_Brett
  Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 1 8,718 10-30-2020, 08:45 AM
Last Post: gbn1980
  Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua TAFATNEB 0 4,891 07-03-2015, 09:57 PM
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,152 12-28-2014, 08:45 AM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,049 12-26-2014, 09:49 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,307 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,218 09-05-2014, 02:03 PM
