Civil Engineering Association eBooks Journals, Papers and Presentations Investigation on Buckling Behavior of Cylindrical Liquid Storage
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
04-11-2013, 11:33 PM
Investigation on Buckling Behavior of Cylindrical Liquid Storage Tanks Under Seismic Excitation: 1st Report — Investigation on Elephant Foot Bulge
Author: Tomohiro Ito, Hideyuki Morita, Koji Hamada, Akihisa Sugiyama, Yoji Kawamoto, Hideyasu Ogo and Eiji Shirai | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASME | pages: 9
abstract
When a thin walled cylindrical liquid storage tank suffers a large seismic base excitation, buckling phenomena may be caused such as bending buckling at the bottom portion and shear buckling at the middle portion of the tank. However, the dynamic behaviors of the tanks is not fully clarified, especially those from the occurrence of buckling to some failures. In this study, bending buckling phenomena were focused which will be categorized as diamond buckling and elephant foot bulge. As ones of a series of studies, dynamic buckling tests were performed using large scale liquid storage tank models simulating thin walled cylindrical liquid storage tanks in nuclear power plants. The input seismic acceleration was increased until the elephant foot bulge occurred, and the vibrational behavior before and after buckling was investigated. In addition to the large scaled model tests, fundamental tests using small scaled tank models were also performed in order to clarify the effects of dynamic liquid pressure on the buckling threshold and deformation patterns.
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • Jackass, shadabg, jcbv, warbeast, malc, subin91, ssobhan, Dell_Brett, slowet, kowheng
  Investigation of the behavior of the cable-stayed bridge under test load TAFATNEB 0 4,030 05-02-2014, 09:19 AM
  Seismic Analysis and Design of Steel Liquid Storage Tanks TAFATNEB 0 3,870 08-31-2013, 11:08 AM
  Seismic Response Analysis of Large Liquid Storage Tank Considering Fluid-Structure In mybest 0 4,396 06-19-2013, 10:56 AM
Last Post: mybest
  Plastic Buckling of Cylindrical Shells: A Theoretical Analysis and Comparison with Te asim99 0 3,826 05-04-2013, 03:33 PM
  Plastic buckling of cylindrical shells under biaxial loading asim99 0 3,585 05-04-2013, 03:27 PM
  Plastic buckling of axially compressed circular cylindrical shells asim99 0 4,065 05-04-2013, 03:20 PM
  Buckling of an axially compressed cylindrical shell of variable thickness asim99 0 3,886 05-04-2013, 03:14 PM
