Civil Engineering Association eBooks Journals, Papers and Presentations COMPRESSION TESTS OF LONG WELDED I-SECTION COLUMNS
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-03-2013, 01:17 PM
Author: A. J. Davids and G. J. Hancock | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1986 | pages: 17
The results of compression tests of long, welded I-section columns
composed of slender plates of high tensile steel are described. Tests of concentrically
loaded specimens are compared with a finite strip nonlinear analysis
model for predicting the elastic interaction of local and overall buckling of thinwalled
columns. Tests of concentrically and eccentrically loaded specimens are
compared with the proposed AISC Load and Resistance Factor Design method
for columns with slender cross sections. The column strengths are also compared
with those of compact columns of equivalent weight to demonstrate the
economies available for columns with slender cross sections.
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  • jcbv, mastermind, malc, kowheng, andersen3, Dell_Brett
  COMPRESSION TESTS OF SHORT WELDED I-SECTIONS asim99 0 3,269 04-03-2013, 01:19 PM
