Civil Engineering Association eBooks Journals, Papers and Presentations Static Pushover Analysis Based on an Energy-Equivalent SDOF System
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-01-2013, 03:53 PM
Author: Grigorios Manoukas,Asimina Athanatopoulou, and Ioannis Avramidis | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: Earthquake Spectra | Year: 2011 | pages: 19
In this paper, a new energy-based pushover procedure is presented in order
to achieve an approximate estimation of structural performance under strong
earthquakes. The steps of the proposed methodology are quite similar to those
of the well-known displacement modification method. However, the determination
of the characteristics of the equivalent single-degree-of-freedom (E-SDOF)
system is based on a different rational concept. Its main idea is to determine the
E-SDOF system by equating the external work of the lateral loads acting on the
multi-degree-of-freedom (MDOF) system under consideration to the strain
energy of the E-SDOF system. After a brief outline of the theoretical background,
a representative numerical example is given. Finally, the accuracy of
the proposed method is evaluated by an extensive parametric study which shows
that, in general, it provides better results compared to those produced by other
similar procedures
[-] The following 11 users Like asim99's post:11 users Like asim99's post
  β€’ LiviuM, ssobhan, 3fan, stigtg, kowheng, eRw1n, Dell_Brett, ting tsai huang, Grunf, rezart, TAFATNEB
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-01-2013, 04:07 PM (This post was last modified: 04-01-2013, 04:08 PM by ssobhan.)
Dear 3fan
Get it here;
For get high quality pdf for paper, you can go to the Professor IOANNIS E. AVRAMIDIS 's personal webpage as the following paper and print the requested paper;
[-] The following 13 users Like ssobhan's post:13 users Like ssobhan's post
  β€’ LiviuM, 3fan, jcbv, seriousboy, gulilero, eRw1n, malc, Dell_Brett, andersen3, Grunf, denysitorus, rezart, TAFATNEB
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 5,118 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,669 08-10-2014, 02:52 PM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 4,367 08-10-2014, 02:48 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,924 08-10-2014, 02:42 PM
  Comparison between Static and Dynamic Analysis of Elevated Water Tank” TAFATNEB 0 5,253 05-10-2014, 09:18 AM
  ANALYSIS ON SEISMIC PERFORMANCE OF ENERGY DISSIPATION SUBSIDIARY PIERS CONSIDERING FO TAFATNEB 0 4,254 05-02-2014, 09:27 AM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 4,289 04-26-2014, 06:15 PM
