Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] NON SWAY AND SWAY METHODS FOR DESIGN OF MULTI-STOREY RC BUILDING: ANALYSIS AND DESIGN
[Request] NON SWAY AND SWAY METHODS FOR DESIGN OF MULTI-STOREY RC BUILDING: ANALYSIS AND DESIGN
 alilo
User ID: 15961
Threads: 1
Likes: 4 in 1 posts
Given Likes: 38
03-25-2013, 09:26 AM
NON SWAY AND SWAY METHODS FOR DESIGN OF MULTI-STOREY RC BUILDING: ANALYSIS AND DESIGN OF RC BUILDING FRAMES BY STAAD. PRO
Noor M. S. Hasan (Author), Habibur R. Sobuz (Author), Costas Ioannou (Author)
ISBN-10: 363933650X
PLEASE IF YOU CAN PROVIDE THIS BOOK
BEST REGARDS
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
03-26-2013, 01:36 PM
this is NOT the book requested but should provide a good insight for the book
concrete solution advocate
[-] The following 8 users Like concreteok's post:8 users Like concreteok's post
  • blaze, ting tsai huang, melekeen, malc, Dell_Brett, ykhackhack, kirankumarklk, cace-01
 ASEC
United States
User ID: 13344
Threads: 11
Likes: 397 in 113 posts
Given Likes: 298
03-27-2013, 03:14 AM
It is actually the same paper in the link provided by concreteok. I bought the book not really a book but a booklet very thin I would not recommend buying it just read the paper it is almost the same content.
My frustration about the booklet is that it did not show what type of lateral bracing is used to qualify as non sway building. It only shows the tabulated output of the non sway building without any explanation what system is used i.e. shear wall, core wall or bracing. It did not mention anything about the effect of rigid diaphragm. It is just a study of basic regular frame structure nothing special.
[-] The following 3 users Like ASEC's post:3 users Like ASEC's post
  • ykhackhack, Dell_Brett, cace-01
  [REQUEST] Building Support structures analysis and design jojopanez 5 6,036 10-21-2019, 04:38 AM
Last Post: wahyoe
  [REQUEST] 3DPUSHOVER 2008 - NONLINEAR STATIC METHODS FOR DESIGN/ASSESSMENT OF 3D STRUCTURES ibmarin 2 2,538 08-19-2014, 01:23 PM
Last Post: rigid_joint
  [REQUEST] A comparison of numerical methods for multi-tied walls ch_surf 1 1,741 07-17-2014, 10:27 PM
Last Post: ssobhan
  [REQUEST] Probability, Reliability, and Statistical Methods in Engineering Design devilmaycry 2 2,285 01-06-2014, 10:33 AM
Last Post: Mohammad6299
  Probability, Reliability and Statistical Methods in Engineering Design iceman84 2 2,727 02-27-2013, 02:32 PM
Last Post: fun113113
  [REQUEST] Manual for the design of building structures to Eurocode 1 and Basis of Str Design rangarajan 1 2,584 01-27-2013, 11:50 PM
Last Post: apocalipse
  [REQUEST] On the behaviour and the analysis of multi-storey infilled frames subjected to latera DamirDz 0 1,549 01-15-2013, 07:44 PM
Last Post: DamirDz
