Civil Engineering Association eBooks Journals, Papers and Presentations COMPARIISON OF R.C.C. AND PRESTRESSED CONCRETE CIIRCULAR WATER TANKS
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
03-23-2013, 05:38 AM
Author: Riyaz Sameer 1, Prof A. R. Mundhada 2, Snehal Metkar3 | Size: 0.45 MB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Emerging Technology and Advanced Engineering | Year: 2012 | pages: 4 | ISBN: -
This paper presents a Comparative study of R.C.C. water tanks vis-à-vis Prestressed concrete water tanks resting over firm ground. The work includes the design and estimates for circular R.C.C. water tanks and prestressed concrete water tanks of various diameter. At times the more than one choice available for construction types leads to confusion. The best way is to select the type of construction, depending on the circumstances and type of structure. The aim of this paper is to design medium diameter R.C.C water tanks as well as pre-stress concrete water tanks variety and then compare the results. Programming in MS EXCEL is done to design the water tanks. The idea is to reach a definite conclusion regarding the superiority of the two techniques over one another. Results reveal that an RCC water tank is cheaper than prestress concrete water tank for smaller diameter but vice versa is true for larger diameter tanks.
[Image: comments.png]
[-] The following 14 users Like aslam's post:14 users Like aslam's post
  • shadabg, smrutigandh.42, rezart, maad59, subin91, blaze, Jackass, gulilero, malc, kowheng, Andrew seah, tluc, Dell_Brett, KhaLed-S.E
  Design of Circular Concrete Tanks mowafi3m 1 5,697 07-21-2014, 07:53 AM
Last Post: bigone
  Precast/Prestressed Concrete Institute Publications rendel_© 12 18,511 10-13-2013, 02:00 PM
Last Post: milova
  A NEW DESIGN METHOD FOR PRESTRESSED CONCRETE CONTINUOUS FLAT SLABS asim99 0 4,667 11-28-2012, 09:45 PM
  Materials and Methods for Corrosion Control of Reinforced and Prestressed Concrete St ir_71 0 4,193 07-08-2011, 04:12 PM
  Self-Compacting Concrete (SCC) for Prestressed Bridge Girders ir_71 0 4,145 03-15-2011, 06:38 AM
  Evaluation and Repair Procedures for Precast/Prestressed Concrete Girders with Longit ir_71 0 5,285 02-19-2011, 05:45 PM
  Prediction of vertical deflections for a long span prestressed concrete bridge struct carolinandra 1 5,261 09-18-2010, 08:24 AM
Last Post: carolinandra
