Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis P-Delta Effects on Steel Moment Frames with Welded Flange Plate Connections
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
02-26-2013, 04:37 PM
P-DELTA EFFECTS ON STEEL MOMENT FRAMES WITH WELDED FLANGE PLATE CONNECTIONS
Author: David Meads | Size: 3.11 MB | Format: PDF | Quality: Unspecified | Publisher: David Meads | Year: 2011 | pages: 49
[Image: 77737263632695347667.jpg]
The P-Delta effect occurs when a frame or structure is laterally displaced by either seismic or wind loadings. As the structure is being displaced laterally, gravity begins to act on the members causing a secondary effect on the forces and moments which in turn cause additional displacement.
The purpose of this study is to investigate the P-Delta effect on multi-story steel framed structures with welded flange plate connections. The traditional method regarding the calculation of the P-Delta effect assumes the lateral displacement of the steel columns is due to lateral deflection only and does not take joint rotation into account. In this study, a finite element analysis using computer models will be used to investigate the additional lateral displacement from the P-Delta effect due to the addition of joint rotation.
[-] The following 11 users Like asim99's post:11 users Like asim99's post
  â€¢ blaze, mahyarov, jcbv, cace-01, malc, Dell_Brett, kowheng, slowet, gacella, qeddy, yanburak
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,999 10-08-2014, 02:00 PM
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,803 11-23-2013, 01:27 PM
  SEISMIC DESIGN OF FRICTION DAMPED BRACED STEEL PLANE FRAMES BY ENERGY METHODS TAFATNEB 0 1,856 08-31-2013, 01:09 PM
  SEISMIC ANALYSIS OF KNEE ELEMENTS FOR STEEL FRAMES TAFATNEB 0 1,728 08-26-2013, 11:43 PM
  P-Delta Effects on Steel Moment Frames with Reduced Beam Section Connection asim99 1 2,148 02-27-2013, 11:29 PM
Last Post: LiviuM
  THE EFFECT OF BOLTED FRAMES ON THE EARTHQUAKE RESISTANCE OF STRUCTURAL STEEL BUILDING asim99 0 1,715 02-08-2013, 10:10 PM
  Multi-scale computational simulation of progressive collapse of steel frames david-smith 2 2,783 06-02-2012, 05:25 PM
Last Post: ssobhan
