Civil Engineering Association eBooks Journals, Papers and Presentations Design methods of integral-lift tubular steel scaffolds for high-rise building const
 amritarao
Indonesia
User ID: 49604
Threads: 29
Likes: 360 in 35 posts
Given Likes: 176
02-24-2013, 06:27 AM
Design methods of integral-lift tubular steel scaffolds for high-rise building construction
Author: F. Yue | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: wiley | Year: 2010 | pages: 10
In this paper, we discuss the design and calculation methods of integral-lift scaffolds under condition of
operating, climbing up/down and falling. Dead loads, construction live loads and wind loads for integral-lift
scaffolds are given in this paper. The key factors such as additional load factor κ are introduced and defi ned
for recommendation as well. Load and resistance factor design method based on probability theory is
introduced for the design of the main load-bearing structures. Herein, the additional partial safety factor
of material strength γ ′
m is introduced specifi cally for scaffolding frames which are often frequently reused
under poor outdoor conditions. Some important checking methods proposed specifi cally for integral-lift
scaffolds such as checking of anti-slide strength of couplers and anti-overturning analyses are also presented. Meanwhile, allowable strength design method is suggested in the design of the lifting equipments,
suspending rods and slings. The proposed methods in this paper will be useful guidelines for safe design
of integral-lift scaffolds.
[-] The following 9 users Like amritarao's post:9 users Like amritarao's post
  • malc, blaze, tluc, kowheng, dinu69in, Dell_Brett, slowet, cace-01, ting tsai huang
  Tall building foundations: design methods and applications RyanRS 0 4,646 01-27-2017, 10:30 AM
Last Post: RyanRS
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 9,171 02-10-2016, 02:49 PM
  Fazlur R. Khan - Current Trends in Concrete High-Rise Buildings RyanRS 0 5,395 09-16-2015, 03:41 AM
Last Post: RyanRS
  Design of High-Rise Buildings RyanRS 0 5,740 06-06-2015, 01:32 PM
Last Post: RyanRS
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,093 09-05-2014, 01:46 PM
  DYNAMIC RESPONSE OF HIGH RISE STRUCTURES UNDER THE INFLUENCE OF DISCRETE STAGGERED SH TAFATNEB 0 4,571 05-30-2014, 01:55 PM
  SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection ir_71 2 7,288 12-18-2013, 08:42 AM
Last Post: bigone
