Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Design for Punching Shear at Int. Columns in Prestressed Conc. Slabs: Resist. to EQ.
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
02-02-2013, 05:43 PM
Design for Punching Shear at Interior Columns in Prestressed Concrete Slabs: Resistance to Earthquakes
Author: Ramez Botros Gayed | Size: 17.5 MB | Format: PDF | Quality: Unspecified | Publisher: Ramez Botros Gayed | Year: 2005 | pages: 341
[Image: 73889898962503071516.jpg]
Experimental and numerical studies were carried out to investigate the punching shear
strength of post-tensioned concrete flat slab-interior column connections under the effects
of gravity loads and lateral displacements induced by earthquakes. Seven full-size posttensioned
slab-interior column connections were tested under gravity loads combined
with cyclic displacement reversals of increasing amplitude up to failure. The ratio of
prestressed to non-prestressed reinforcement was varied, while the flexural strength was
constant. The slabs were reinforced with headed studs, a type of shear reinforcement that
had been developed at the University of Calgary. The objective of this experimental
program was to verify the applicability of the seismic provisions of the North American
codes as well as other seismic design procedures, proposed earlier, when used for
prestressed slabs.
[-] The following 18 users Like asim99's post:18 users Like asim99's post
  â€¢ cace-01, pelon2040, kowheng, aslam, viet2010, malc, maad59, Dell_Brett, thebeatles, knrsa, civilphongvan, ibg0203, blaze, Jackass, ruaumoko, mahyarov, tang1942, KhaLed-S.E
  the contribution of no structural component to the overall dynamic behavior of conc TAFATNEB 0 1,699 08-08-2014, 04:11 PM
  SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS TAFATNEB 0 1,801 06-01-2014, 03:41 PM
  PUNCHING SHEAR STRENGTH AND DE FORMATION CAPACITY OF FIBER REINFORCED CONCRETE SLAB-C TAFATNEB 0 1,804 06-01-2014, 03:30 PM
  Seismic Retrofitting w/ Cost Effectiveness: SBF, SMF, Conc. Shear Wall & Conc. Mo. Fr asim99 0 2,030 02-26-2013, 05:09 PM
  Analysis of the Strength and Stability of Prestressed Conc. Through-Girder Pedestrian asim99 0 1,855 02-02-2013, 05:36 PM
