Civil Engineering Association Software Software Product Bentley Products RAM Structural System V8i 14.05 SELECTSeries 5
Threads: 1,118
12-22-2012, 03:15 PM
[Image: 93537547623590005331.jpg]
[Image: 42460943915161424543.jpg]
[Image: 28997565793428586504.jpg]
Version: 14.05.02.00 Date: 11/2/2012
The RAM Structural System is powerful and versatile special purpose software for the analysis and design of building structures. It is useful in the design and analysis of commercial, institutional and industrial buildings. The RAM Structural System automates the process of calculating tributary loads, live load reduction, gravity member selection, frame analysis, drift control, frame member and joint code checking, special seismic provisions member and joint checking and foundation design. By automating these tedious and time consuming processes, the engineer can quickly obtain an accurate design. Different framing configurations may be examined in a short period of time, resulting in substantial timesaving for the Engineer and a more economical design for the client. The interface with CAD software permits rapid generation of framing plans, saving significant drafting time and reducing the errors associated with manual information transfer.
The RAM Structural System is composed of a number of special purpose modules, each of which is invoked from the RAM Manager. The RAM Modeler provides for the creation of a model of the entire structure, including roof and floor loads; beam, column, brace and wall geometry and locations; and slab properties, openings and edges. Powerful, yet easy to use graphical model generation features are provided which allow complex floor and building systems to be modeled in a short time. The result is a comprehensive database of building data which can be accessed by the analysis and design modules, providing a completely integrated solution.
[Image: comments.png]
Must be installed
Bentley IEG License Service 02.00.20.01
For VIP the struceng solution in Post #4 here:
works. How to use see post #1. If you need password ask struceng.
Other users enjoy the trial and please don't ask for solution (this is only for VIP)
[-] The following 14 users Like BennyP's post:14 users Like BennyP's post
  β€’ cordoba123, Dell_Brett, kowheng, StaadEng, ykhackhack, bigone, mohcivil, jokerβ„’, haze, Andrew seah, cybermad, 3fan, affihussain, Rodmo376
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-19-2013, 09:37 AM
Mirror RAM Structural System V8i 14.05 SELECTSeries 5
No limits to creativity
[-] The following 2 users Like jokerβ„’'s post:2 users Like jokerβ„’'s post
  β€’ Dell_Brett, Rami11
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
01-19-2013, 03:07 PM
[-] The following 3 users Like jokerβ„’'s post:3 users Like jokerβ„’'s post
  β€’ oanm2000, Dell_Brett, JOGAR71
  Bentley RAM Structural System v24 poolmand 0 3,182 10-08-2024, 08:47 AM
  Bentley RAM Structural System v23 poolmand 0 4,179 10-04-2023, 08:19 AM
  RAM Structural System CONNECT Edition V15 Update 11 er.shyams 0 5,503 10-16-2018, 10:00 AM
Last Post: er.shyams
  RAM Structural System CONNECT Edition V15 Update 8 er.shyams 0 4,919 05-01-2018, 01:59 PM
  RAM Structural System CONNECT Edition 15.03.00.00 TAFATNEB 0 5,544 10-28-2016, 08:30 AM
  RAM Structural System V8i Version: 14.05.04.00 marion33 5 15,406 07-22-2015, 06:32 PM
  RAM Structural System v8i BennyP 9 23,819 04-26-2013, 11:51 AM
Last Post: ykhackhack
