Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Simplifying Bridge Expansion Joint Design and Maintenance
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-17-2012, 12:31 PM
Author: Caicedo, Juan M University of South Carolina, Columbia Wieger, Glen Ziehl, Paul Rizos, Dimitris | Size: 1.84 MB | Format: PDF | Quality: Original preprint | Publisher: University of South Carolina, Columbia | Year: 2011 | pages: 57
[Image: 61959377502753145661.png]
This report presents a study focused on identifying the most durable expansion joints for the South Carolina Department of Transportation (SCDOT). This is performed by proposing a degradation model for the expansion joints and updating it based on bridge inspections. Open expansion joints and pourable joint seal were found to be the best performing joints based on the proposed degradation models. Assembly joints and compression joint seal have an intermediate performance and strip seal expansion joints have the lowest performance of the type of expansion joints studied. Assembly joints are found to be problematic because of the different moving parts composing the joint. A significant number of bridge joint failures are caused because of incorrect installation, in particular, joints with complex anchor systems between the bridge deck and expansion joint. The SCDOT standards were found to be up to date and comparable to other Department of Transportation standards in terms of the design and installation aspects of bridge joints. A recommendation is made to request a warranty for the installation when appropriate. Other general best practices during the installation of the expansion joint include: 1) when possible, install joints when the ambient temperature is the average of the range of temperatures in the area. This allows the joint to be installed close to the β€œundeformed” position of the bridge; 2) the support of the joint should be installed in good quality, cured concrete; and 3) avoid splices of any pre-manufactured material. If splices cannot be avoided, place the splice outside the wheel path.
[-] The following 12 users Like mahyarov's post:12 users Like mahyarov's post
  β€’ kowheng, Jackass, oanm2000, gulilero, Dell_Brett, Andrew seah, malc, eliseo.as, ssi3k, slowet, blaze, chenamoy
  Bridge Maintenance, Safety, Management and Life-Cycle Optimization i_kabir 4 5,196 12-31-2021, 08:04 PM
Last Post: Veggeta
  Innovative bridge design handbook : construction, rehabilitation and maintenance cace-01 2 4,532 11-28-2021, 06:01 PM
Last Post: cace-01
  Bridge Engineering: Design, Rehabilitation, and Maintenance of Modern Highway Bridges poolmand 0 3,146 07-13-2021, 05:54 AM
  Bridge Engineering: Rehabilitation, and Maintenance of Modern Highway Bridges Dell_Brett 12 9,571 10-16-2018, 05:18 PM
Last Post: febo927
  Highway Bridge Maintenance Planning and Scheduling - 1st Edition febo927 0 1,722 09-25-2018, 12:35 PM
Last Post: febo927
  Bridge Bearings and Expansion Joints - by David J Lee triance 3 5,011 12-11-2015, 12:42 PM
  Operation and maintenance of bridge access gantries and runways. 2nd edition arshiakh 1 2,197 11-22-2015, 09:26 PM
