Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Bearing Capacity Analysis and Design of Highway Base Materials Reinforced with Geofab
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-12-2012, 09:00 PM
Bearing Capacity Analysis and Design of Highway Base Materials Reinforced with Geofabrics
Author: Hopkins, Tommy C Sun, Liecheng Slepak, Mikhail E | Size: 2.97 MB | Format: PDF | Quality: Original preprint | Publisher: University of Kentucky, Lexington | Year: 2005 | pages: 119
[Image: 39201396433957689930.png]
The primary objective of this study was to develop and implement mathematical bearing capacity models originally proposed by Hopkins (1988, 1991) and Slepak and Hopkins (1993, 1995). These advanced models, which are based on limit equilibrium and are operated together, can be used to analyze the bearing capacity, or stability, of early construction of loads on a single layer of material, two-layered problems involving a layer of base aggregate and subgrade, and a foundation involving multiple layers of different materials, such as flexible asphalt pavement. A Prandlt-type shear surface is used in the model analyses of layered foundations. In this report, the models are extended to analyzing flexible pavements reinforced with tensile elements. Although the current model does not account for strain compatibility, the strength of the tensile elements may be input for assumed strain levels. Any number of tensile elements may be analyzed in a given problem. In the limit equilibrium approach, shear strengths, the angle of internal friction, phi, and cohesion, c, are entered for each layer of material. Triaxial testing of the asphalt material is performed in a manner that the shear strength parameters, phi and c, are developed as a function of temperature. Hence, if the temperature of the asphalt layer is known (or assumed) at a site, then values of phi and c may be calculated from the relationships between the shear strength parameters and temperature. Moreover, to facilitate and provide an efficient means of analyzing early construction cases and flexible pavements reinforced with geosynthetics, "Windows" software was developed. In the case of the asphalt layer, the entire layer is divided into finite layers because phi and c varies with depth of asphalt. When the surface temperature of the asphalt is known (or assumed), a temperature distribution model is used to estimate the temperature at any depth below the asphalt layer surface. Consequently, the shear strength parameters are known at any depth (of each finite layer) below the surface. To establish the validity and reasonableness of the newly developed limit equilibrium models, bearing capacity factors are derived from the limit equilibrium methods and compared to classical bearing capacity factors, N sub c and N sub q, developed by Prandlt and Reissner. Differences range from 1 to 10 and 1 to 3%, respectively. The Slepak-Hopkins model yields values of N sub y that are 12 to 38 larger than values published by Caquot and Kerisel. However, values of N sub y from the Slepak-Hopkins model are only 3 to 11% larger than backcalculated values obtained by Debeer and Ladanyi from experimental footing tests. The Slepak-Hopkins model was also used to analyzed 237 flexible pavement sections of the 1959-1960 AASHO Road Test. Factors of safety from the model analyses showed that very reasonable results were obtained and were in line with failures recorded at the test site. Finally, actual analyses of a stretch of roadway where failures occurred were analyzed. Three sections involved tensile elements.
[-] The following 5 users Like mahyarov's post:5 users Like mahyarov's post
  â€¢ kowheng, oanm2000, Dell_Brett, Evandrojr, uetian19
  Shallow Foundations: Bearing Capacity and Settlement - Braja M. Das babak 12 9,404 02-23-2017, 12:37 PM
  USACoE - Bearing Capacity of Soils Hengki 2 3,011 04-30-2016, 05:17 PM
  The Bearing Capacity of Building Foundations bridgeengineer 0 1,670 04-19-2016, 01:44 PM
Last Post: bridgeengineer
  Design Methods for the REinforcement of Highway Slopes by Reinforced Soil... elitvdis 2 3,106 09-22-2010, 04:29 PM
Last Post: ziggywas1
