Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering A Precast Bridge Bent System for Seismic Regions
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
11-12-2012, 08:42 PM
Author: Marsh, M Lee | Size: 794 KB | Format: PDF | Quality: Original preprint | Publisher: BergerABAM | Year: 2010 | pages: 24
This report describes a precast concrete bridge bent system that is suitable for high seismic zones. Lateral load tests on both the top (column-to-cap) and bottom (column-to-footing) connections of the system have demonstrated that the connections have strengths and ductilities similar to those of comparable cast-in-place connections. Additional tests on the bottom connection of the system are ongoing, and construction of a demonstration bridge project will begin later this year. The final development of this system is partially funded by the FHWA’s Highways for LIFE Technology Partnerships Program (DTFH61-09-00005).
  • oanm2000, Jackass, mgdario, Dell_Brett
  Design of Precast Concrete Piers for Rapid Bridge Construction in Seismic Regions mahyarov 0 1,605 10-27-2012, 04:06 PM
Last Post: mahyarov
  Precast Concrete Pier Systems for Rapid Construction of Bridges in Seismic Regions mahyarov 0 1,537 10-27-2012, 04:03 PM
Last Post: mahyarov
  Seismic Assessment and Retrofit of Existing Multi-Column Bent Bridges mahyarov 0 1,569 10-27-2012, 03:55 PM
Last Post: mahyarov
  Seismic Response of Precast Segmental Bridge Superstructures mahyarov 0 1,568 10-27-2012, 03:28 PM
Last Post: mahyarov
  A pre-cast concrete bridge bent designed to re-center after an earthquake mahyarov 0 1,653 10-27-2012, 02:39 PM
Last Post: mahyarov
  Seismic Behavior and Design of Segmental Precast Post-Tensioned Concrete Piers mahyarov 0 1,581 10-27-2012, 01:48 PM
Last Post: mahyarov
  Seismic Performance of an I-Girder to Inverted-T Bent Cap Connection mahyarov 0 1,493 10-27-2012, 01:43 PM
Last Post: mahyarov
