Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Evaluation of Long-Term Prestress Losses in Post-Tensioned Box-Girder Bridges
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
10-30-2012, 08:18 AM
Author: Shing, P Benson Kottari, Alexandra | Size: 1.37 MB | Format: PDF | Quality: Original preprint | Publisher: University of California, San Diego | Year: 2011 | pages: 90
[Image: 12115747684568476799.png]
This study assessed the accuracy of the long-term prestress-loss estimation methods given in the current AASHTO LRFD Specifications for post-tensioned bridge girders, and developed more suitable analysis methods for these members. A refined analysis method and a simplified method were proven to be accurate using field data collected from two bridge structures that were monitored for prestress losses over a period of more than four years. Formulas for calculating the creep and shrinkage of concrete have been evaluated with the material data obtained from concrete cylinders cast with the same batches of concrete used for the monitored bridge girders, and have been used for the loss calculations. The formulas in AASHTO 2004 provide a much better correlation with the creep and shrinkage data obtained from the concrete cylinders than AASHTO 2007. In general, the AASHTO 2007 formulas significantly under-estimate the creep and shrinkage of the concrete cylinders, and result in calculated long-term losses that are much lower than the measured values. The creep and shrinkage formulas provided in AASHTO 2004 therefore are recommended for the prestress-loss calculations using the proposed refined analysis method. Suggestions are provided for possible implementation of the proposed analysis methods in the AASHTO LRFD Specifications for calculating long-term prestress losses in post-tensioned bridge girders. Both methods are expressed in forms that can be readily implemented in the AASHTO LRFD Specifications.
  • kowheng, cace-01, triance, blaze
  Inspection, Evaluation and Maintenance of Suspension Bridges Case Studies RyanRS 3 2,741 10-01-2018, 04:51 PM
Last Post: febo927
  Inspection, Evaluation and Maintenance of Suspension Bridges - 1st Edition febo927 0 1,594 09-25-2018, 12:56 PM
Last Post: febo927
  Series: New Directions for Florida Post-Tensioned Bridge gulilero 1 1,921 03-18-2016, 06:33 PM
Last Post: inge911
  AASHTO - Guide Specifications for Horizontally Curved Steel Girder Highway Bridges chrono146 1 2,974 07-02-2014, 03:35 PM
Last Post: i_kabir
  Structural Health Monitoring of Long-Span Suspension Bridges ir_71 3 3,099 04-30-2014, 05:56 PM
Last Post: joker™
  Analysis and Design of Curved Box Girder Bridges marion33 1 2,681 10-26-2013, 08:25 AM
Last Post: al_frd
  Historic Bridges: Evaluation, Preservation, and Management struceng 4 3,561 08-09-2013, 02:57 PM
Last Post: axcel
