Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Insights from Depth-Averaged Numerical Simulation of Flow at Bridge Abutments in Comp
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
10-29-2012, 07:27 AM
Predicting Camber, Deflection, and Prestress Losses in Prestressed Concrete Members
Author: Morales, Reinaldo Ettema, Robert | Size: 4.49 MB | Format: PDF | Quality: Original preprint | Publisher: University of Wyoming, Laramie | Year: 2011 | pages: 123
[Image: 19310614217975397872.png]
Two-dimensional, depth-averaged flow models are used to study the distribution of flow around spill-through abutments situated on floodplains in compound channels and rectangular channels (flow on very wide floodplains may be treated as rectangular channels). The study leads to useful insights regarding distributions of flow velocity, unit discharge, and boundary shear stress at spill-through abutments. It also presents insights from extensive assessment of uncertainty associated with the use of depth-averaged modeling of flow at abutments. Of substantial use for design determination of abutment scour at bridge waterways is estimation of the magnitude of peak values of flow velocity, boundary shear stress, and unit discharge in the region where scour develops. The study, by showing how abutment flow fields adjust in response to variations of abutment length, floodplain width, and main channel dimensions, yields important trends regarding the magnitude of amplification factors for depth-averaged velocity, unit discharge, bed shear stress, and distance to peak unit discharge. Early studies are shown to provide rather limited and inadequate amplification values associated only with a narrow range of abutment and channel geometries examined. The present study comprises a much broader range of abutment lengths, channel shapes, and floodplain dimensions than heretofore reported in the literature. The study’s insights, from its assessment of uncertainty associated with the use of depth-averaged modeling of flow at abutments, yield a relationship for estimating the optimum mesh size for use with depth-averaged models. The relationship is applicable to other subsequent studies using depth-averaged models of flow around abutments or similar hydraulic structures. Prior studies addressing the effect of mesh size on numerical error have not provided a recommendation for an average optimum mesh size. The study also gives focused recommendations for topics requiring further investigation.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  • cace-01, blaze, kowheng
  Design and Construction Guidelines for Geosynthetic-Reinforced Soil Bridge Abutments mahyarov 2 2,490 10-22-2015, 02:24 PM
Last Post: PinkPant
  Deterioration of J-Bar Reinforcement in Abutments and Piers mahyarov 0 1,400 10-29-2012, 06:49 AM
Last Post: mahyarov
  Seismic Design of Geosynthetic-Reinforced Soil Bridge Abutments with Modular Block Fa mahyarov 0 1,656 10-24-2012, 06:59 PM
Last Post: mahyarov
  Countermeasures to Protect Bridge Abutments from Scour mahyarov 0 1,374 10-24-2012, 05:42 AM
Last Post: mahyarov
  NCHRP R587: Countermeasures to Protect Bridge Abutments from Scour kowheng 0 1,792 03-25-2011, 09:35 AM
