Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Finite Element Analysis of Deep Wide-Flanged Pre-stressed Girders to Understand and C
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
10-29-2012, 07:02 AM
Finite Element Analysis of Deep Wide-Flanged Pre-stressed Girders to Understand and Control End Cracking
Author: Oliva, Michael G | Size: 9.48 MB | Format: PDF | Quality: Original preprint | Publisher: University of Wisconsin, Madison | Year: 2011 | pages: 132
[Image: 07274537333275325152.png]
Hundreds of prestressed concrete girders are used each year for building bridges in Wisconsin. The prestress transfer from the prestressing strands to concrete takes place at the girder ends. Characteristic cracks form in this end region during or immediately after detensioning. Potential solutions to control end cracking were examined via finite element models and the impact of each solution on cracking was evaluated. Modifications to reinforcement bar size, debonding ratios, strand cutting sequence and use of draped strand patterns were simulated by the models. The results from different analyses were compared to quantify the success of each method in reducing strains causing girder end cracks. The tension strains leading to cracks of all types were responsive to debonding some of the bottom flange prestressing strands. Bottom flange cracking can be prevented by methodically debonding exterior strands, keeping the draped strands bonded, and evenly distributing the remaining bonded strands over the bottom flange.
  • blaze, cace-01, kowheng, mgdario
  The Design of Pre-Stressed Concrete Bridges Ultra Zone 15 11,897 03-02-2016, 04:17 PM
Last Post: ibg0203
  Finite Element Analysis and Design of Steel and Steel-Concrete Composite Bridges asim99 1 2,268 07-11-2014, 03:46 AM
Last Post: i_kabir
  SELF-STRESSED SANDWICH BRIDGE DECKS mahyarov 0 1,604 11-10-2012, 01:06 PM
Last Post: mahyarov
