Civil Engineering Association eBooks Traffic Engineering NCHRP - Guide for Pavement Friction
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
10-25-2012, 04:05 PM (This post was last modified: 09-14-2014, 04:11 PM by usman.)
Author: Houston, William N | Size: 2.67 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2009 | pages: 257 | ISBN: -
[Image: 05573046063002499558.png]
Performance objectives for achieving durable bridge deck concrete and the properties of locally available concrete raw materials, particularly supplementary cementitious materials (SCMs) like fly ash, GGBFS and silica fume, vary by geographic region. Because of this variation, the optimum concrete mixture proportions for a given application must be determined by experiment. Since durability-related experimental programs investigating the performance of concrete mixtures are expensive and time-consuming, a methodology for designing and conducting an investigation using statistical experimental design concepts has been developed to efficiently identify the optimum concrete mixture proportions for a specific set of conditions. The approach implemented is based on fractional orthogonal experimental design, which supports modeling for a large number of factors (input variables) based on a minimum number of tests. The Methodology, presented in NCHRP Report 566: "Guidelines for Concrete Mixtures Containing Supplementary Cementitious Materials to Enhance Durability of Bridge Decks," consists of six steps: (1) definition of performance requirements, (2) selection of durable raw materials, (3) construction of an experimental design matrix, (4) testing of concrete mixtures, (5) analysis and empirical modeling to determine the Best Tested and Best Predicted Concretes, and (6) confirmation of predictions and selection of the Best Concrete. This Methodology is flexible and may be applied to a range of performance demands. It was developed to identify optimum contents of SCMs but is also able to select between sources of raw materials. A case study was conducted based on a hypothetical set of service conditions and using concrete raw materials from the Midwest. The performance predictions based on the case study experimental design were verified by confirmation testing. Finally, a computational tool (SEDOC) was developed to support the implementation of this Methodology.
  • oanm2000, kowheng, cace-01, Mohammad6299
  AASHTO - Mechanistic-Empirical Pavement Design Guide - A Manual of Practice cace-01 2 2,854 05-29-2018, 03:30 PM
Last Post: axcel
  ACPA - EB220 Life Cycle Cost Analysis A Guide for Comparing Alternate Pavement Design mybest 1 2,338 03-13-2015, 04:51 AM
Last Post: p_vosoughi
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 3,100 01-26-2015, 03:50 AM
Last Post: gulilero
  AASHTO - Guide for the Local Calibration of the Mechanistic-Empirical Pavement Design Saze808 0 1,790 09-14-2014, 12:41 PM
Last Post: Saze808
  NCHRP - S401 Quality Management of Pavement Condition Data Collection mahyarov 0 1,715 10-25-2012, 08:18 PM
Last Post: mahyarov
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,716 10-24-2012, 10:59 AM
Last Post: mahyarov
  NCHRP - R512 Accelerated Pavement Testing: Data Guidelines mahyarov 0 1,549 10-24-2012, 09:19 AM
Last Post: mahyarov
