Civil Engineering Association eBooks Traffic Engineering Cost-Effective Connection Details for Highway Sign, Luminaire, and Traffic Signal Str
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-25-2012, 02:18 PM
Cost-Effective Connection Details for Highway Sign, Luminaire, and Traffic Signal Structures
Author: Roy, S Lehigh University Park, Y C Lehigh University Sause, R Lehigh University Fisher, J W Lehigh University Kaufmann, E J Lehigh University | Size: 9.73 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2011 | pages: 236 | ISBN: -
[Image: 74810026409083885506.png]
This report documents the results of a comprehensive experimental and analytical study that evaluated fatigue performance of several critical welded connections in the highway sign, signal and high-level luminaire support structures. In this study, infinite life fatigue resistance of connection details in the existing inventory was established and new cost-effective fatigue resistant connections were developed. About 80 full size galvanized specimens of sign, signal and high-level luminaire support structures containing different welded connections were fatigue tested. Using parametric Finite Element Analyses (FEA) of 3D models verified by test data, fatigue performance of the connections in both finite and infinite life regimes were defined in terms of fatigue stress concentration factors over the range of applicable geometric dimensions. The study demonstrated that tube-to-transverse plate connections are the most fatigue critical details in the subject structures. Increasing the stiffness of the transverse plate is the most cost-effective means of improving fatigue resistance of this connection. Groove welded connections with smaller opening in the plate exhibits largest fatigue resistance. Sharper bend radius and less number of sides reduce fatigue threshold of connections in multi-sided sections. Based on these research findings, new specification recommendations were proposed for revision to the existing AASHTO specifications.
  â€¢ oanm2000, gulilero, Dell_Brett, cace-01, Mohammad6299, ykhackhack, blaze
  Principles of Highway Engineering and Traffic Analysis (5th Edition) cace-01 3 5,692 01-20-2022, 01:01 PM
Last Post: cace-01
  Traffic and Highway Engineering, Enhanced Edition 5th Edition ir_71 11 8,062 11-22-2021, 06:58 AM
  Highway and Traffic Engineering in Developing Countries - 1st Edition febo927 0 3,188 09-26-2018, 05:25 PM
Last Post: febo927
  Fatigue-Resistant Design of Cantilevered Signal, Sign, and Light Supports mahyarov 0 1,548 10-24-2012, 10:50 AM
Last Post: mahyarov
  Structural Supports for Highway Signs, Luminaires, and Traffic Signals mahyarov 0 4,373 10-24-2012, 10:07 AM
Last Post: mahyarov
  Guidance for Cost Estimation and Management for Highway Projects During Planning, Pro mahyarov 0 1,804 10-24-2012, 06:01 AM
Last Post: mahyarov
  Highway and Traffic Engineering for Deeveloping Countries Smithy 4 3,464 10-17-2012, 12:29 PM
Last Post: shadabg
