Civil Engineering Association eBooks Traffic Engineering Simple Performance Test for Superpave Mix Design
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-24-2012, 10:56 AM
Author: Witczak, M W Kaloush, K Pellinen, T El-Basyouny, M Von Quintus, H | Size: 6.03 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2002 | pages: 111 | ISBN: 0309067154
[Image: 49879386411568378590.png]
This report presents the findings of a research task to identify a simple test for confirming key performance characteristics of Superpave volumetric mix designs. In this initial phase of the work, candidate tests for permanent deformation, fatigue cracking, and low-temperature cracking were identified and recommended for field validation in the next phase of work. The report will be of particular interest to materials engineers in state highway agencies, as well as to materials suppliers and paving contractor personnel responsible for design and production of hot mix asphalt.
  â€¢ blaze, kowheng, Mohammad6299, cace-01, oanm2000, Dell_Brett, pram
  Development of Criteria for Using the Superpave Gyratory Compactor to Design Airport mahyarov 0 2,009 11-17-2012, 12:39 PM
Last Post: mahyarov
  New Simple Performance Tests for Asphalt Mixes mahyarov 0 1,862 10-27-2012, 09:07 AM
Last Post: mahyarov
  Lessons Learned from the AASHO Road Test and Performance of the Interstate Highway Sy mahyarov 0 1,971 10-27-2012, 08:37 AM
Last Post: mahyarov
  Adapting Specification Criteria for Simple Performance Tests to HMA Mix Design mahyarov 0 1,631 10-25-2012, 02:27 PM
Last Post: mahyarov
  The Superpave Mix Design System: Anatomy of a Research ProgramThe Superpave Mix Desig mahyarov 0 1,580 10-24-2012, 07:03 PM
Last Post: mahyarov
  Volumetric Requirements for Superpave Mix Design mahyarov 0 1,460 10-24-2012, 06:07 AM
Last Post: mahyarov
