Civil Engineering Association eBooks Traffic Engineering Guidance for Cost Estimation and Management for Highway Projects During Planning, Pro
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-24-2012, 06:01 AM
Guidance for Cost Estimation and Management for Highway Projects During Planning, Programming, and Preconstruction
Author: Anderson, Stuart | Size: 7.57 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2007 | pages: 294 | ISBN: 9780309098755
[Image: 39790094024112842925.png]
This guidebook presents approaches to cost estimation and management to overcome the root causes of cost escalation and to support the development of consistent and accurate project estimates through all phases of the development process, from long-range planning, through priority programming, and through project design. A research team led by the Texas Transportation Institute carried out a comprehensive investigation into current and effective practices for cost estimation and management during the various planning and project development phases prior to construction. The project resulted in this practical guidebook. The guidebook should be of significant use to managers, practitioners, and decision makers interested in development and management of realistic and accurate cost estimates for transportation projects from the earliest stages of planning through final project design. The guidance provided is intended to provide methods and tools that will reduce unintended or unanticipated escalation of costs as transportation projects proceed through the development process.
  â€¢ kowheng, Dell_Brett, Mohammad6299, cace-01, oanm2000, Grunf
  Highway engineering : planning, design, and operations cace-01 0 1,905 03-30-2017, 01:37 PM
Last Post: cace-01
  Airport Planning & Management, 5th Edition NAUTILUS87 6 5,133 10-27-2014, 05:31 PM
Last Post: r3be1
  Airport Systems: Planning, Design, and Management sodapas 2 3,308 04-06-2013, 10:09 AM
Last Post: arshiakh
  Performance-Based Highway Maintenance and Operations Management mahyarov 0 1,851 10-25-2012, 07:51 PM
Last Post: mahyarov
  Extent of Highway Capacity Manual Use in Planning mahyarov 0 2,007 10-25-2012, 07:48 PM
Last Post: mahyarov
  Guidance for Transportation Project Management mahyarov 0 1,548 10-25-2012, 03:03 PM
Last Post: mahyarov
  Cost-Effective Connection Details for Highway Sign, Luminaire, and Traffic Signal Str mahyarov 0 1,522 10-25-2012, 02:18 PM
Last Post: mahyarov
