Civil Engineering Association eBooks Journals, Papers and Presentations Analysis and Design of Drilled Shaft Foundations Socketed into Rock
Threads: 154
10-04-2012, 08:48 AM
Author: J.P.Carter & F.H.Kulhawy | Size: 5.3 MB | Format: PDF | Quality: Scanner | Publisher: Cornell University, Empire State Electric Energy Research Corporation & Electric Power Research Institute | Year: 1988 | pages: 190
[Image: 34095302356224285307.jpg]
It's the Final report of an Research Project :
Abstract :
A Comprehensive investigation has been made of the behavior of drilled shaft foundation shocked into rock. Methods of analysis have been presented to predict the ultimate capacity and the load displacement behavior under axial load (compression or uplift), lateral load or moment, and torsion. Simple approximate models have been developed which allow closed form predictions for all of these loading modes.. The models for axial loading have been used in the interpretation of 25 load tests from the literature to deduce the likely range of design parameters. Only two load tests were available for lateral load analysis, and no torsional load tests were available. More data are needed from these loading modes for model verification. A detailed design example also is included to illustrate the use of the design equations presented.
[-] The following 10 users Like shadabg's post:10 users Like shadabg's post
  â€¢ blaze, Dell_Brett, kowheng, zrilek, Evandrojr, david-smith, malc, utan, Jackass, eng donny
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,180 10-21-2014, 08:57 AM
Last Post: Munykong
  The evaluation of impedance functions in the analysis of foundations vibrations using TAFATNEB 1 5,710 08-11-2014, 10:26 AM
  Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Eff TAFATNEB 0 4,093 11-23-2013, 11:32 PM
  Review of drilled shaft foundation design of high angle electrical transmission strc. jacs1976 0 3,942 10-07-2013, 04:28 PM
Last Post: jacs1976
  Analysis of Ultimate Loads of Shallow Foundations shadabg 0 4,338 11-02-2012, 12:37 PM
Last Post: shadabg
  DRILLED SHAFT FOUNDATIONS FOR THE kcICON MISSOURI RIVER BRIDGE shadabg 0 3,577 09-12-2012, 11:40 AM
Last Post: shadabg
  numerical modelling for rock mechanics and rock engineering youceftli 1 5,423 10-31-2011, 09:02 PM
Last Post: youceftli
