Civil Engineering Association eBooks Journals, Papers and Presentations Superabsorbent Polymers — An Additive to Increase the Freeze-Thaw Resistance of ...
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
08-11-2012, 10:41 AM (This post was last modified: 08-11-2012, 10:52 AM by lisine.)
Superabsorbent Polymers — An Additive to Increase the Freeze-Thaw Resistance of High Strength Concrete
Author: Sven Mönnig, Pietro Lura | Size: 0.28 MB | Format: PDF | Quality: Original preprint | Publisher: Advances in Construction Materials 2007, Part V, | Year: 2007 | pages: 351-358
This paper presents the results of freeze thaw resistance tests performed on a reference mixture and a mixture with superabsorbent polymer (SAP) addition. The SAP mixture showed 40% less scaling than the reference mixture and a slight increase of the compressive strength. A simulation performed with the Hard Core Soft Shell model (HCSS) explains the good performance of the SAP mixture with the formation of a number of small, spherical and closely-spaced voids within the cement paste, which have the same function as air entrainment.
This is paper is part of the Advances in Construction Materials 2007 which can be found here
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • yakwetu, malc, Dell_Brett, kowheng, Jackass, zrilek
  Use of Supplementary Cementing Materials to Increase the Resistance to Chloride Ion P asim99 0 3,463 04-29-2013, 05:06 PM
  Freeze-Thaw Resistance of Concrete With Marginal Air Content ir_71 0 3,854 02-16-2011, 06:05 AM
