Civil Engineering Association Software Software Product Bentley Products SewerCad 5.6 Unlimited Pipes
 betinnn
Mexico
User ID: 34
Threads: 8
Likes: 219 in 13 posts
Given Likes: 93
04-03-2012, 08:08 PM (This post was last modified: 04-03-2012, 11:44 PM by oanm2000.)
SewerCAD is an extremely powerful program for the design and analysis of gravity flow and pressure flow through pipe networks and pumping stations. The program can be run in AutoCAD mode, giving you all the power of AutoCAD’s capabilities, or in Stand-Alone mode utilizing our own graphical interface.
SewerCAD allows you to construct a graphical representation of a pipe network containing information such as pipe data, pump data, loading, and infiltration. You have a choice of conveyance elements including circular pipes, arches, boxes and more.
The gravity network is calculated using the built-in numerical model, which utilizes both the direct step and standard step gradually varied flow methods. Flow calculations are valid for both surcharged and varied flow situations, including hydraulic jumps, backwater, and drawdown curves. You also have the flexibility to mix gravity and pressure components freely, building your systems in parallel or in series as they exist in the field. Pressure elements can be controlled based on system hydraulics, turning pumps on and off due to changes in flows and pressures.
SewerCAD’s flexible reporting feature allows you to customize and print the model results in both a report format and as a graphical plot.
[Image: tips.png]
[align=left][Image: download.png]
[-] The following 8 users Like betinnn's post:8 users Like betinnn's post
  • nexus, MOSS2000, jorgeramos, Vincwilson, mgdario, zzzz, mr.nicus, bigone
 mazzam
User ID: 34732
Likes: 1 in 1 posts
Given Likes: 3
03-25-2014, 07:19 PM
The link is broken
[-] The following 1 user Likes mazzam's post:1 user Likes mazzam's post
  • trmpereira
  Bentley SewerCAD v8i (SELECT series 2) 08.11.02.49 (30 Days Trial) BennyP 2 11,724 12-04-2011, 03:45 PM
  Bentley SewerCAD v8i (SELECT series 2) 08.11.02.46 (5 Days Trial) BennyP 0 7,074 08-04-2010, 03:13 PM
