Civil Engineering Association eBooks Codes, Manual & Handbook LRFD for Wood Construction
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 98
Likes: 2,410 in 167 posts
Given Likes: 2238
02-10-2009, 06:12 PM (This post was last modified: 08-24-2009, 06:25 PM by oanm2000.)
LRFD for Wood Construction ( Structural Use Panels )
This supplement contains adjustment factors, dimensions, factored resistance, reference strengths and other properties required to design structural-use panels in the LRFD format. In this format, the term “resistance” is used to refer to member capacities (i.e., moment resistance, compression resistance, etc.). This is distinct from the term “strength” which refers to limit state material properties — conceptually a “factored allowable stress.”
The member resistance values tabulated in this supplement are to be used in conjunction with the design methodologies provided in AF&PA/ASCE 16-95, Standard for Load and Resistance Factor Desig(LRFD) for Engineered Wood Construction.
The reference strengths were derived according to the principles of ASTM D5457-93, Standard Specification for Computing the Reference Resistance of Wood-based Materials and Structural Connections for Load and Resistance Factor Design.
The tabulated reference strength values are to be used within the reference end-use conditions defined therein. When the end-use conditions fall outside the range of the reference conditions, the reference values shall be adjusted by the product of applicable adjustment factors as defined in AF&PA/ASCE 16-95 and also provided in this supplement. For unusual end-use conditions, the designer should consult additional literature for possible further adjustments.
[Image: structuralusepanels.jpg?w=234&h=300]
LRFD for Wood Construction ( Structural Glued Laminated Timber )
This supplement contains adjustment factors, dimensions, factored resistance, reference strengths and other properties required to design structural glued laminated timber in the LRFD format. In this format, the term “resistance” is used to refer to member capacities (i.e., moment resistance, compression resistance, etc.). This is distinct from the term “strength” which refers to limit state material properties — conceptually a “factored allowable stress.”
The member resistance values tabulated in this supplement are to be used in conjunction with the design methodologies provided in AF&PA/ASCE 16-95, Standard for Load and Resistance Factor Design (LRFD) for Engineered Wood Construction.
The reference strengths were derived according to the principles of ASTM D5457-93, Standard Specification for Computing the Reference Resistance of Wood-based Materials and Structural Connections for Load and Resistance Factor Design. The tabulated reference strength values are to be used within the reference end-use conditions defined therein. When the end-use conditions fall outside the range of the reference conditions, the reference values shall be adjusted by the product of applicable adjustment factors as defined in AF&PA ASCE 16-95 and also provided in this supplement. For unusual end-use conditions, the designer should consult additional literature for possible further adjustments.
[Image: structuralgluedlaminatedtimber.jpg?w=233&h=300]
LRFD for Wood Construction ( Example Problems )
[Image: wood-example-problem.jpg?w=233&h=300]
________________________________________________________________
Post edited. All links are working
Follow the Rules
[-] The following 5 users Like Ultra Zone's post:5 users Like Ultra Zone's post
  • andi jackson, NAUTILUS87, imatoric, fer962933, sivlad
  Wood Handbook- Wood as an Engineering Materials rendel_© 5 5,335 03-08-2017, 05:39 PM
  ANSI/AF&PA NDS-2005: National Design Specification for Wood Construction cmepe 6 6,845 03-27-2016, 03:37 AM
Last Post: RICARDI
  Egyptian Code of Practice for Steel Construction - LRFD 2008 AG.NAYEL 3 4,752 01-19-2016, 09:31 AM
Last Post: heogay43
  NATIONAL DESIGN SPECIFICATION (NDS) FOR WOOD CONSTRUCTION lucky_b2me 1 3,369 05-17-2010, 12:20 AM
Last Post: Badis
