Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Evaluation Of Pushover Analysis Procedures For Frame Structures
 abouferass88
Yemen
User ID: 11928
Threads: 37
Likes: 598 in 75 posts
Given Likes: 237
02-12-2012, 10:22 PM (This post was last modified: 07-20-2012, 10:45 AM by Dell_Brett.)
EVALUATION OF PUSHOVER ANALYSIS PROCEDURES FOR FRAME STRUCTURES
Author: SERMİN OĞUZ | Size: 5.62 MB | Format: PDF | Quality: Original preprint | Year: 2005 | pages: 168
[Image: 39232468910245099403.png]
ABSTRACT
Pushover analysis involves certain approximations and simplifications that some amount of variation is always expected to exist in seismic demand prediction of pushover analysis. In literature, some improved pushover procedures have been proposed to overcome the certain limitations of traditional pushover procedures.
The effects and the accuracy of invariant lateral load patterns utilised in pushover analysis to predict the behavior imposed on the structure due to randomly selected individual ground motions causing elastic and various levels of nonlinear response were evaluated in this study. For this purpose, pushover analyses using various invariant lateral load patterns and Modal Pushover Analysis were performed on reinforced concrete and steel moment resisting frames covering a broad range of fundamental periods. Certain response parameters predicted by each pushover procedure were compared with the 'exact' results obtained from nonlinear dynamic analysis. The primary observations from the study showed that the accuracy of the pushover results depends strongly on the load path, properties of the structure and the characteristics of the ground motion.
Pushover analyses were performed by both DRAIN-2DX and SAP2000. Similar pushover results were obtained from the two different softwares employed in the study provided that similar approach is used in modeling the nonlinear properties of members as well as their structural features.
The accuracy of approximate procedures utilised to estimate target displacement was also studied on frame structures. The accuracy of the predictions was observed to depend on the approximations involved in the theory of the procedures, structural properties and ground motion characteristics.
[-] The following 28 users Like abouferass88's post:28 users Like abouferass88's post
  • 3fan, malc, bhawk0, kowheng, Jackass, jaejeong, Batman07, ting tsai huang, learner20, tluc, ruaumoko, Quantumm, orambo, erthqkengnr™, yantonegr, NBZ1400, nigema, sodapas, tpipkpo, engrezi, sructme, Sumatra, oram, cace-01, ykhackhack, Dell_Brett, TAFATNEB, rezart
 warbeast
User ID: 20502
Threads: 28
Likes: 716 in 74 posts
Given Likes: 1728
07-19-2012, 10:51 AM
DIRECT Link :
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 14 users Like warbeast's post:14 users Like warbeast's post
  • kostis, 3fan, lisine, cace-01, vvvv, SCREAM7890, ykhackhack, subin91, gulilero, Dell_Brett, TAFATNEB, nickycruz, engrezi, rezart
08-26-2013, 11:21 PM
Author: SERMİN OĞUZ | Size: 5.61 MB | Format: PDF | Quality: Unspecified | Year: APRIL 2005 | pages: 168
Pushover analysis involves certain approximations and simplifications that someamount of variation is always expected to exist in seismic demand prediction of pushoveranalysis. In literature, some improved pushover procedures have been proposed toovercome the certain limitations of traditional pushover procedures.The effects and the accuracy of invariant lateral load patterns utilised in pushover
[-] The following 15 users Like TAFATNEB's post:15 users Like TAFATNEB's post
  • dinu69in, Dell_Brett, malc, gulilero, psk62, ykhackhack, knrsa, slowet, cace-01, sodapas, mgdario, rezart, learner20, blaze, simanta
  Advanced Analysis of Steel Frame Structures Subjected to Lateral Torsional Buckling E TAFATNEB 0 2,041 10-06-2014, 10:36 AM
  APPLICATION OF PUSHOVER ANALYSIS TO RC BRIDGES TAFATNEB 0 1,976 04-11-2014, 09:26 AM
  PUSHOVER ANALYSIS OF AN EXISTING REINFORCED CONCRETE STRUCTURE TAFATNEB 0 1,980 09-04-2013, 09:03 AM
  Nonlinear Static Pushover Analysis of a Shear Wall Building in Madinah TAFATNEB 0 1,903 08-26-2013, 11:27 PM
  TOWARD ADVANCED ANALYSIS IN STEEL FRAME DESIGN asim99 0 1,771 12-31-2012, 02:30 AM
  Investigation of pushover analysis procedures for reliability-based and performance mybest 0 1,850 11-05-2012, 12:25 PM
Last Post: mybest
