Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SSI & Its Roles in Perform.-Based Seism Analysis of Shear Wall Struct (PhD
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
01-23-2012, 04:17 AM
SSI and Its Roles in Performance-Based Seismic Analysis of Shear Wall Structures (PhD Thesis)
Author: Yuchuan Tang | Size: 3.2 MB | Format: PDF | Quality: Original preprint | Publisher: University of California, Los Angeles | Year: 2009 | pages: 287
ABSTRACT
In order to systematically assess the complex soil-structure interaction (SSI) effects on the seismic responses of shear wall structures, this dissertation deals with several critical and inter-related topics under the framework of performance-based earthquake engineering. Firstly, the study develops improved pulse representations for earthquake ground motions that govern the peak structural responses. Based on rigorous dimensional analysis, the dimensionless Il-response spectra are derived for both linear and bilinear SDOF systems. They are shown to be congruent with the corresponding (dimensional) response spectrum in bi-logarithmic plotting. This leads to a novel approach to identify pulse parameters that match simultaneously the kinematic characteristics and the response spectrum of the original ground motion. The improved pulse representations can potentially be used as the intensity measures of earthquake ground motions. Secondly, the SSI effects of lumped soil-foundation-structure interacting (SFSI) systems are investigated through the dimensional analysis with pulse motions as input.
The dimensionless terms that govern the interactive behavior of SFSI systems are derived. The SSI effects are related explicitly and directly to the characteristics of input ground motions and the properties of SFSI systems. The conditions under which the SSI effects amplify or reduce the structural responses are also identified. Subsequently, dynamic responses of strip foundations bonded on linear or nonlinear soil half-space are investigated using the finite element method. The dynamic foundation responses are found to depend on the amplitude and frequency of input motion, foundation geometry, and soil properties. The energy dissipation through radiation damping for nonlinear soil case is reduced and can be quantified with two alternative factors related to the yielding of soil medium.
Finally, the SSI effects are evaluated for a realistic shear wall structure using the probabilistic seismic demand analysis where the nonlinear hysteretic behavior of shear walls and foundations are accurately modeled. Either the inelastic spectral displacement or the pulse representation is adopted as the intensity measure of input ground motions. The damage probability of the shear wall generally decreases when the SSI effects are considered for this case study.
Advisor: Professor Jian Zhang
[-] The following 10 users Like Sumatra's post:10 users Like Sumatra's post
  • malc, tluc, kowheng, Gkatzogias, Grunf, Jackass, techno, sodapas, sructme, ykhackhack
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
01-29-2012, 07:14 AM
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  • Grunf, ykhackhack
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
01-29-2012, 07:55 AM
No limits to creativity
[-] The following 2 users Like joker™'s post:2 users Like joker™'s post
  • Grunf, ykhackhack
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,814 03-27-2015, 11:44 AM
  STEEL DISSIPATIVE BRACING SYSTEMS FOR SEISMIC RETROFITTING OF EXISTING STRUCT TAFATNEB 0 1,796 10-08-2014, 02:17 PM
  In Situ Dynamic Characteristics of Reinforced Concrete Shear Wall Buildings mybest 1 2,274 04-08-2014, 10:33 AM
Last Post: Grunf
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,660 11-23-2013, 01:27 PM
  Nonlinear Static Pushover Analysis of a Shear Wall Building in Madinah TAFATNEB 0 1,749 08-26-2013, 11:27 PM
  Seismic Retrofitting w/ Cost Effectiveness: SBF, SMF, Conc. Shear Wall & Conc. Mo. Fr asim99 0 1,866 02-26-2013, 05:09 PM
  Displacement-based Seismic Design of Shear Wall Buildings hich 2 2,646 05-03-2012, 04:42 AM
Last Post: miquan
