Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis RANSFER LENGTH, DEVELOPMENT LENGTH, FLEXURAL STRENGTH, AND PRESTRESS LOSS EVALUATION
 Haseeb Jamal
User ID: 9152
Threads: 34
Likes: 674 in 72 posts
Given Likes: 125
01-27-2010, 05:20 PM (This post was last modified: 01-19-2012, 04:11 PM by Administrator.)
TRANSFER LENGTH, DEVELOPMENT LENGTH, FLEXURAL STRENGTH, AND PRESTRESS LOSS EVALUATION IN PRETENSIONED SELF-CONSOLIDATING CONCRETE MEMBERS
[img][Image: 18867890658633356689.jpg][/img]
ABSTRACT
The first objective of this thesis was to determine the effect of using self-consolidating
concrete versus normal concrete on transfer and development lengths, and flexural strengths of
prestressed members. Three small rectangular members were made, two cast with SCC mixes
and one cast with a conventional mix, to determine the transfer length of each mix. Transfer
lengths of both ends of each member were determined by measuring the concrete surface strains.
The change in the transfer length was monitored by determining the transfer length of each
member at prestress release, 7 days after release, and 28 days after release. All concrete mixes
had lower than code determined transfer lengths at prestress release. Each concrete mix showed between a 12 to 56 percent increase in transfer length after 28 days. One SCC mix exceeded the ACI code stipulated 50 strand diameters 7 days after prestress transfer. The other SCC mix was consistently below the transfer length of the conventional concrete.
Separate development length members were cast in a stay-in-place steel form used for
creating structural double tees. Each development length member was a stub tee. Iterative load
testing was performed to determine the development length of each SCC and conventional mix.
Development lengths for both SCC mixes were approximately 20 percent shorter than ACI and
AASHTO code predictions. A development length for the conventional concrete was not
determined due to non-repeating test data. The flexural strength of each member was determined during load testing. All concrete mixes achieved higher than the ACI predicted strengths.
The second objective of this thesis was to experimentally measure prestress losses and
compare these experimental values to theoretical models. Crack initiation and crack reopening
tests were performed to experimentally determine the prestress losses in each member. Three
theoretical models were evaluated, the sixth edition PCI Design Handbook suggested model, a
1975 PCI Committee on Prestress Losses model, and the AASHTO LRFD prestress loss model.
The crack initiation experimental values tended to be between 10 and 15 percent lower than
theoretical models. In general, the crack reopening prediction of the effective prestress had a good correlation with theoretical models.
[img][Image: 34239890503307365279.jpg][/img]
[-] The following 9 users Like Haseeb Jamal's post:9 users Like Haseeb Jamal's post
  β€’ Civil Engineer, kowheng, simanta, abtcivileng, cristi, ruaumoko, chigozie, TAFATNEB, SCREAM7890
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-29-2012, 08:14 AM
Dead Links Disappointment , plz Re-upload
No limits to creativity
[-] The following 2 users Like jokerβ„’'s post:2 users Like jokerβ„’'s post
  β€’ lambert, SCREAM7890
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,430 11-17-2013, 08:49 AM
Last Post: st77bel
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN|2003 Haseeb Jamal 2 2,727 02-19-2012, 02:18 AM
Last Post: Jackass
  Theoretical Effective Length Factors for Cross-Braced Solid Round Diagonals yanburak 0 2,196 09-04-2010, 09:03 AM
Last Post: yanburak
