Civil Engineering Association eBooks Water & Hydraulic Engineering Pipeline Planning and Construction Field Manual
05-13-2011, 06:49 PM (This post was last modified: 05-13-2011, 06:51 PM by ir_71.)
Author: E. Shashi Menon | Size: 38.8 MB | Format: PDF | Publisher: GULF PROFESSIONAL PUBLISHING | Year: 2011 | pages: 576 | ISBN: 9780123838674
[Image: 15491763762681651972.jpg]
Description
The objective of this book is to provide engineers with the necessary tools and techniques for formulating plans, designs, cost estimates and specifications for pipeline construction and field maintenance and modernization programs. Packed with easy to read and understand tables, pipeline schematics, bullet lists and "what to do next" checklists. This easy to use book covers the design, construction, and operation of onshore pipeline systems. The incorporate construction methods, commissioning, pressure testing, and start up into the design of a pipeline system. The focus is on pipeline routing, mechanical design, construction methods, hydraulics, installation, and operations of onshore pipeline systems. With this book readers will acquire and/or consolidate the essential knowledge and skills to design, construct, and operate pipelines. Design and simulation problems are an integral part of this book. With this book in hand, engineers will be able to:
Routine auditing of technical work output relative to technical input and established criteria and expectations.
Assessment and estimation of work scope including pipeline design integrity and resourcing requirements from enquiry through to project completion.
To carry out conceptual designs in support of concept selection studies.
Audience:
Piping Engineers, Designers, Civil Engineers, Mechanical Engineers, Petroleum Engineers, Chemical Engineers, Project Production Engineers and Project Reservoir Engineers
Contents:
1. Design Basis
2. Route Selection
3. Alignment Sheets
4. Wall Thickness Definition
5. Pipeline Analyses
6. Pipeline End Expansion Analysis
7. Tie-In Spool Expansion Spool and Riser Design
8. Corrosion Protection
9. Specification Writing, Data Sheet Production, Requisition Development & Bid Analysis of Associated Materials and Valves
10. Installation Studies
  β€’ seriousboy, hcardenas, malc, kowheng, almadar12, knrsa, Dell_Brett, henrycv, lanz, portal61, zbizafar, jokerβ„’, draluka, jacky899
 Ivan_1980
User ID: 31818
Threads: 7
Likes: 204 in 12 posts
Given Likes: 951
12-16-2011, 08:03 PM (This post was last modified: 12-17-2011, 01:06 PM by Grunf.)
Author: E. Shashi Menon, Ph.D., P.E. | Size: 4.61 MB MB | Format: PDF | Publisher: ELSEVIER | Year: 2011 | pages: 577 | ISBN: 978-0-12-383867-4
[Image: 19880683784603600597.jpg]
There are thousands of pipelines crisscrossing the globe, both onshore and offshore. Designing, constructing, and operating these pipelines and their appurtenant facilities require special skills along with experience. Design criteria and construction techniques differ from area to area and knowing where and how to access such criteria is essential for pipeline professionals.
This book was prepared in order to give engineers and technicians a working knowledge of the processes of planning, designing, and construction of a pipeline system. The idea for the book was conceived by Elsevier Senior Acquisitions Editor, Kenneth McCombs, in consultation with Shashi Menon, a professional engineer with over 37 years of experience in the US Oil and Gas industry. In addition, we assembled a team of experts with over 180 years combined experience throughout the United States and the world to collaborate on the book and produce a relevant and useful reference manual for pipeline planning and construction.
[-] The following 20 users Like Ivan_1980's post:20 users Like Ivan_1980's post
  β€’ seb3k, NBZ1400, Dell_Brett, kowheng, malc, almadar12, cigutierrezg, henrycv, kerenski_t, Jackass, sasan7351, OSHO, teo912009, vic_med, cristi, shanta, lisine, subin91, zrilek, mohamz
 Flexi
User ID: 300
Likes: 5,440 in 422 posts
Given Likes: 110
03-04-2012, 06:13 AM
other links:
regards
Flexi
[-] The following 4 users Like Flexi's post:4 users Like Flexi's post
  β€’ jokerβ„’, GMianG, jacky899, shanta
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
06-10-2013, 09:51 AM
(Grabbed from FreeBook site)
  β€’ betinnn, Trishu999, zrilek, jaejeong
Users browsing this thread:
  Small Dams - Planning, Construction and Maintenance junaid 3 2,781 12-07-2016, 12:01 AM
  PIPELINE DESIGN & CONSTRUCTION A PRACTICAL APPROACH malc 2 3,060 04-10-2014, 03:00 PM
Last Post: cace-01
  Irrigation Systems: Design, Planning and Construction junaid 1 2,302 10-29-2010, 10:04 AM
