Civil Engineering Association eBooks Codes, Manual & Handbook ANSI/HI 9.8-1998 PUMP INTAKE DESIGN
 malc
User ID: 30599
Threads: 65
Likes: 1,520 in 155 posts
Given Likes: 15191
11-19-2011, 11:36 AM
Author: HYDRAULIC INSTITUTE | Size: 1 MB | Format: PDF | Publisher: HYDRAULIC INSTITUTE | Year: 1998 | pages: 77 | ISBN: 1880952262
[Image: 02099169718646269868.jpg]
Scope: This standard provides intake design recommendations for both suction pipes and all types of wet pits While specific intake design is beyond the scope of the pump manufacturer’s responsibility their comments maybe helpful for the intake designers.
[Image: comments.png]
Support this Institute work if you get a direct benefit. it will be good if you share a more recent version of this important standard. Have a great lecture.
[-] The following 4 users Like malc's post:4 users Like malc's post
  β€’ Jackass, hcardenas, almadar12, oanm2000
  ANSI/API RECOMMENDED PRACTICE 2EQ FIRST EDITION, NOVEMBER 2014 Seismic Design malc 0 1,668 08-30-2021, 06:25 AM
Last Post: malc
  ANSI/NAAMM FP 1001-07 GUIDE SPECIFICATIONS FOR DESIGN OF METAL FLAGPOLES ir_71 2 3,291 09-28-2020, 08:25 AM
Last Post: civilfafa
  ANSI/ASHRAE 189.1-2009: Standard for the Design of High-Performance Green Buildings oanm2000 3 4,119 09-15-2017, 01:13 PM
  ANSI/AF&PA SDPWS-2008 Special Design Provisions for Wind and Seismic with Commentary ir_71 2 3,468 05-28-2016, 12:02 PM
Last Post: PinkPant
  ANSI/AF&PA NDS-2005: National Design Specification for Wood Construction cmepe 6 6,845 03-27-2016, 03:37 AM
Last Post: RICARDI
  Norway NORSOK Standard - Design of Steel Structures (1998) tamboon 1 2,516 02-06-2012, 12:39 PM
Last Post: kvtasp
  ANSI/SPRI RP-4 2008 Wind Design Standard For Ballasted Single-ply Roofi ng Systems ir_71 0 2,049 04-26-2011, 04:27 AM
