Civil Engineering Association eBooks Journals, Papers and Presentations Frost Durability of Roller-Compacted Concrete Pavements
Threads: 1,298
10-21-2011, 04:08 AM
Size: 3 MB | Format: PDF | Publisher: PCA | Year: 2004 | pages: 150 | ISBN: 0893122378
[Image: 01581962828931793122.jpg]
The growth of roller-compacted concrete pavement use in cold climate regions often is impeded by concerns regarding its ability to resist frost attack. Most published laboratory test results have indicated that the frost resistance and particularly the deicer salt-scale resistance of RCC are not always satisfactory. However, long-term field performance indicates that non-air entrainment RCC can be quite resistant to frost action. The report provides a comprehensive review on the current practices and recent developments in material selection and aggregate gradation, mixture design methods, production process and placement techniques. Improved construction techniques and recent developments in mixture design methods have resulted in stronger more durable RCC. Data shows that as little as 1.5% of spherical air bubbles can have a beneficial influence on the frost resistance durability of RCC. Test results indicate that ASTM C 1262 appears to be a reliable method of assessing the frost durability of RCC.
  • kowheng, Dell_Brett, blaze, dizz, malc, Jackass, lisine, gulilero
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 5,137 03-31-2014, 10:46 PM
  Design and Construction of Roller Compacted Concrete Pavements in Quebec ir_71 1 6,495 01-21-2013, 02:44 PM
Last Post: jacs127
  Revised Builder’s Guide to Frost Protected Shallow Foundations ir_71 1 5,458 06-10-2012, 05:46 PM
Last Post: psppsp
  USACoE - Roller-Compacted Concrete ir_71 1 5,469 10-24-2011, 08:28 PM
Last Post: usman
  Pervious Concrete Pavements ir_71 0 4,492 04-30-2011, 05:42 AM
  Frost and Scaling Resistance of High-Strength Concrete ir_71 0 3,741 04-18-2011, 04:57 AM
  Rubblization of Portland Cement Concrete Pavements ir_71 1 5,297 03-29-2011, 11:54 AM
Last Post: 3fan
