Civil Engineering Association eBooks Structural Books Steel European Recommendations for Slip Factors of Connections with H.S.F.G. Bolts
07-19-2011, 08:11 AM (This post was last modified: 12-13-2011, 09:42 PM by usman.)
ECCS 037 - Slip Factors of Connections with H.S.F.G. Bolts
Author: TC 10 | Size: 3.14 MB | Format: PDF | Publisher: ECCS | Year: 1984 | pages: 111 | ISBN: OL14286584M (open library ID number)
[Image: 40144966234581732526.jpg]
Abstract:
Compiles the results of tests performed in order to obtain information on the magnitude of the slip factor that may be adopted in design calculations for structural connections formed with high-strength friction grip bolts, partly in view to comparing different surface treatments and partly to determining the effects of atmospheric actions, dust, dirt, grease and oil.
Subjects:
Mechanical fixing products (anchors, bolts, nails, etc.)
Uploaded: Jul/19/2011
[-] The following 21 users Like Grunf's post:21 users Like Grunf's post
  • Clouseau, kowheng, Jackass, malc, vvvv, blaze, seriousboy, oanm2000, jcbv, zrilek, joker™, hcardenas, jferrer, tluc, Trishu999, dinu69in, yanburak, cristi, chenamoy, vkkr, Dell_Brett
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
06-08-2012, 12:09 PM
Direct link:
[-] The following 7 users Like ssobhan's post:7 users Like ssobhan's post
  • david-smith, zrilek, gulilero, knrsa, Dell_Brett, ruaumoko, Jackass
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,894 05-14-2020, 09:19 AM
Last Post: agelos100
  European Recommendations on the Stabilization of Steel Structures by Sandwich Panels agelos100 2 2,745 01-28-2018, 02:04 PM
Last Post: PinkPant
  ECCS No125 - Buckling of Steel Shells, European Design Recommendations, Eurocode 3, Part 1-6 , 5th jcbv 6 3,830 07-09-2015, 03:09 PM
Last Post: monter
  European Recommendations for Steel Structures in Seismic Zones - ECCS54 peixoto 1 2,868 12-18-2013, 07:09 AM
  ECCS No021 european recommendations for the Design and Testing of Connections in Stee david-smith 1 2,087 11-16-2012, 09:16 AM
  European Recommendations for Sound Insulation in Multi-Storey Buildings ir_71 2 2,178 06-08-2012, 08:47 AM
Last Post: ssobhan
  European Recommendations for the Design of Longitunally Stiffened Webs and of Stiffen ir_71 2 2,386 06-08-2012, 08:43 AM
Last Post: ssobhan
