Civil Engineering Association Software Software Product Bentley Products Bentley CivilStorm V8i SELECT Series 2 08.11.02.65 (30 days trial and renew)
Threads: 1,118
05-28-2011, 01:23 PM
[Image: 95235608517672048846.gif]
Bentley CivilStorm V8i simulates your entire stormwater system within one intuitive scaled layout model for the MicroStation, Stand-Alone, or AutoCAD environments. The Bentley CivilStorm V8i dynamic stormwater modeling engine calculates runoff hydrographs and analyzes the hydraulic response through interdependent systems of inlets, pipes, channels, culverts, and ponds.
Bentley CivilStorm V8i helps you:
Avoid Costly Oversights
Stormwater components can dramatically impact each other. With Bentley CivilStorm V8i, you can quickly check for any domino effects between interdependent elements in the system to identify backwater storage effects and bottlenecks in the system that can result in costly unexpected flooding.
Visualize Dynamic Flooding
Bentley CivilStorm V8i provides a rich variety of presentation tools that make it easy for you and your clients to visualize flooding problems and how they can be eliminated. Animate profiles, plan views, and other presentations to observe water levels rising and falling over the course of a storm event.
Design Efficient Solutions
Bentley CivilStorm V8i provides "What if?" scenario management for pre- and post-development analysis, system rehabilitation, and other circumstances. Directly compare results for pre/post conditions or analyze the differences between design possibilities.
Bentley CivilStorm V8i features:
Dynamic integration of rainfall, runoff, surface flow, storm sewers, open channels, culverts, and pondsβ€”in one model
True scaled layout environment, in a stand-alone environment or directly inside AutoCAD
Looped systems with diversions
Pressure and gravity profiles
Fast and stable computations
Infiltration and runoff
Unit hydrograph methods
Complex pond outlet structures
Capture and carryover between inlets
Hydraulic grade profile animations
Animated color mapping
Customizable presentations and graphs
Flexible management tools, from units to modeling options to a graphical environment
[Image: tips.png]
Tested in Windows 7 x64 using the crack posted in Lavteam by Istigatore. The registry patch transform the software to Trial Unlimited Size but after 30 days the trial expire. I added a file (BentNew.exe). Running it will restore the 30 days trial. And by the way it will restore the trial period for almost every Bentley trials posted here.
[-] The following 13 users Like BennyP's post:13 users Like BennyP's post
  β€’ oanm2000, thanzawtun, josephwsl, malc, snakes, Dell_Brett, emmi, shezira, nuttapolk, Vanfa, ska51, vinnunsam, ginof0
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
11-12-2011, 11:43 PM
Mirror Install File
I think your's IP is banned from Bentley (Your Location or Country)
No limits to creativity
[-] The following 1 user Likes jokerβ„’'s post:1 user Likes jokerβ„’'s post
  β€’ ska51
Threads: 1,118
12-02-2011, 04:39 AM
Bentley Civilstorm V8i - Cumulative Patch Set for build 08.11.02.65
(Version: 08.11.02.65 Date: 10/17/201) 2.47 MB
  β€’ ska51, caleno, jacs1976
Threads: 1,118
12-04-2011, 03:44 PM
(Version: 08.11.02.75 Date: 11/7/2011) 267.45 MB
  β€’ fefdbi
 saherboy
User ID: 5416
Threads: 16
Likes: 279 in 37 posts
Given Likes: 45
02-29-2012, 11:33 AM (This post was last modified: 02-29-2012, 11:41 AM by BennyP.)
Hi
Link
Password
ForCivilEA
Here the link
[-] The following 1 user Likes saherboy's post:1 user Likes saherboy's post
  β€’ fefdbi
  Bentley OpenFlows CivilStorm 2024 poolmand 0 4,067 05-12-2024, 07:37 AM
  Bentley OpenFlows CivilStorm CONNECT Edition v10.X poolmand 0 3,486 11-16-2021, 07:39 AM
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 17,015 09-25-2017, 06:25 PM
Last Post: Aviator
  Bentley CivilStorm V8i SS5 08.11.05.113 ibg0203 0 4,899 02-23-2016, 02:56 PM
Last Post: ibg0203
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,757 09-28-2015, 08:38 PM
Last Post: jokerβ„’
  RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 25,425 08-23-2015, 06:24 AM
Last Post: ykhackhack
  RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 37,934 08-18-2015, 09:00 AM
