Civil Engineering Association eBooks Journals, Papers and Presentations Strengthening of Masonry Arches with Fiber-Reinforced Polymer Strips
 Apache
User ID: 261
Threads: 27
Likes: 575 in 49 posts
Given Likes: 199
03-31-2011, 07:24 PM
[Image: 68708012529111781944.jpg]
This paper deals with masonry arches and vaults strengthened with surface fiber-reinforced polymer (FRP) reinforcement in the form of strips bonded at the extrados and/or intrados, considering strip arrangements that prevent hinged mode failure, so the possible failure modes are: (1) crushing, (2) sliding, (3) debonding, and (4) FRP rupture. Mathematical models are presented for predicting the ultimate load associated with each of such failure modes. This study has shown that the reinforced arch is particularly susceptible to failure by crushing, as a result of an ultimate compressive force being collected by a small fraction of the cross section. Failure by debonding at the intrados may also be an issue, especially in the case of weak masonry blocks or multiring brickwork arches. Failure by sliding has to be considered if the reinforcement is at the extrados and loading is considerably nonsymmetric.
[-] The following 6 users Like Apache's post:6 users Like Apache's post
  â€¢ Grunf, kowheng, gafi, zrilek, monter, fer962933
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,932 06-01-2015, 05:11 PM
  EISMIC EVALUATION AND STRENGTHENING OF EXISTING REINFORCED CONCRETE BUILDINGS — GUIDE TAFATNEB 0 5,015 04-12-2014, 10:06 PM
  Seismic retrofit of masonry buildings with polymer grid TAFATNEB 0 4,223 04-03-2014, 12:50 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,803 04-03-2014, 12:26 PM
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 5,208 04-08-2013, 08:00 AM
  Strengthening of Reinforced Concrete Beam-Column Joints eng2010 1 6,844 01-14-2013, 07:00 AM
  Structural Retrofitting of Reinforced Concrete Beams using carbon fibre reinf.polymer cordoba123 0 4,736 10-09-2012, 08:57 PM
Last Post: cordoba123
